Old 06-17-2014, 11:27 PM   #251
Originally Posted by FandRChambers View Post
Wow Ke5rbd, you put some work in. Can you share pictures of your work?
Here are some quick Photos I took today. Getting ready to go to Yellowstone Next week. The ladders strap to the ramp door on the inside with ratchet straps. The carpet goes behind the bikes. When setup we remove the center E track back to the bed. The outside E tracks are out of the walk area. When the bikes are out there is some shelving added to the close hanging rack. Also put 2 inch memory foam on the beds in the garage and 3 inch on front mattress. Makes hugh difference in the comfort as the mattresses aren't real comfortable. They are foam, but sure don't remember very well, especially on large folks like me.
Don't know if you can see any of them but I bored 4 holes I think 1 1/4" at the floor level below the windows. Two on each side. I put chrome electrical plugs in the holes. My thinking is if you get a leak you may be able to discover it before the windows fall out on the ground and get it fixed and dried up before it is too late. That fiberglass insulation will soak up water and stay wet until the wood rots out. Pain in rear to fix and can be expensive. My experience with corrugated siding is the seal around the windows will leak and before you even know it you got a really big problem. The Fiberglass sidewalls usually have styrofoam laminated to the inside and outside wall and some have aluminum framing which is pretty forgiving on leaks and many times less likely to happen. I speak from experience on all this.
Name:	chairs tie downs street side.jpg
ID:	55661   Click image for larger version
Name:	Clothes hanger rod.jpg
ID:	55662   Click image for larger version
Name:	TV Mount.jpg
ID:	55663   Click image for larger version
Name:	Motorcycle tied down.jpg
ID:	55664   Click image for larger version
Name:	window tie down.jpg
Ke5rbd is offline   Reply With Quote
Old 06-18-2014, 09:17 AM   #252
FandRChambers's Avatar
Nice, I was thinking of something against the wall to hold my chairs. Awesome job. So do you like the memory foam?
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 06-18-2014, 12:40 PM   #253
I like the memory foam. We also put a mattress topper on top of the foam and makes it even better. The 3" is better than the 2". Young folks don't tend to notice it. Us more seniors do.
The rails are all Oak as is the tv mount board. Plan to stain to match the cabinets when not using the Camper for a while to let the smell out.
I wouldn't go any deeper in the walls than 1" with the screws as they aren't real thick. If you can find studs you are better to use them. May help to get a stud finder. they aren't always where you think they are.
Old 06-24-2014, 11:17 PM   #254
Anyone had their chain break on the rear bed rail? Anyone know what size chain it is? Out camping and hoping to repair it while I am out...thanks
Fred & Teresa
2002 EZGO Golf Cart
Old 06-25-2014, 10:53 AM   #255
I haven't had this problem, but I'm willing to help where I can. Have you tried calling Happijac (801) 544-2585 ?
2013 Puma Unleashed 351THSS with Goose Box
2006 F350 KR DRW
bluefinger is offline   Reply With Quote
Old 06-25-2014, 11:21 AM   #256
No I haven't. .
called dealership and waiting on a call back. Thanks
Fred & Teresa
2002 EZGO Golf Cart
Old 06-25-2014, 11:28 AM   #257
toylover's Avatar
Haven't heard of a chain break in the bunks before is this rare... hope so. Did you exceed the weight limits ?
toylover is offline   Reply With Quote
Old 08-03-2014, 11:27 AM   #258
cwoods's Avatar
Picked up a 2015 351 THSS on the 31st. Now what?
cwoods is offline   Reply With Quote
Old 08-03-2014, 02:28 PM   #259
Oaklevel's Avatar
Congrats.....Enjoy it & have fun.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 08-03-2014, 04:22 PM   #260
doodler's Avatar
Nice. Now put it to use.
Here is a pic of mine I got in June 2014
doodler
doodler is offline   Reply With Quote
