If you will search "puma unleashed modifications" on here, on page two there is some discussion about this. Sorry I don't know how to post link in here for you.
x 2
Also some have turned the "L" brackets holding the bed frames over to gain more head room
Look inside the rails....from top down...you should see the wire running to the switch held in place by a screw...unscrew and move to the position you choose
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
Can someone post a pic of the limit switch for the beds in the garage? I have looked at the rear vertical rails several times and see no limit switch to relocate in a higher position.........
Take a look at this pagein the Puma Unleashed Modifications Thread doodler mentioned, don't forget to remove the "stop screws" on both sides of the rail.
