02-16-2014, 11:05 AM
#221
Cosmo's Dad
We have two Honda Ranchers and they both fit. I park the first one all the way forward on the drivers side, the other one is more toward the rear on the passenger side of the unit. This allows for more space between the units and for access into the garage through the rear door when in transit mode.
2012 Puma Unleashed 356QLB
2012 F350 Lariat Diesel
2-2011 Honda Rancher quads
1- Spoiled Rotten English Springer Spaniel
02-16-2014, 11:18 AM
#222
Originally Posted by Horribilis
Anyone have the internal measurements of the garage?
I have the bunk beds in the garage. Distance between the rails is 90". Distance between the walls is 93". The distance from the rear door to the walls on the front of the garage is 11'4".
02-20-2014, 03:35 PM
#223
Does anyone use any of the products on the rubber of your slide out? My unit is only a year old but as the weather breaks I'll start getting it ready for the season. Wondering if that something I need to do. I do keep grease on the metal part underneath.
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
02-20-2014, 05:01 PM
#224
I pulled the trigger. I've got a 351thss on order. Hoping that its maiden voyage is Easter weekend.
02-20-2014, 07:12 PM
#225
Slide Conditioner
Its been awhile since I've read my manual but seem to recall the use of lubricants on the slide mech or seals is not recommended. Don't quote me on that though as I too have thought of doing the same thing. You would think even Armorall on the seal would be better than letting it go dry.
Any others out there with first hand knowledge of this maintenance matter?
Thanks and here is to a great 2014 camping season!
Ricky, DW Terry, 11 Kids and Grandkids who all want to go camping with me! Life is good!!
2021 Ram Longhorn Limited 6.7 Cummins HO AISIN DRW CC, B&W 25K, 2021 Cedar Creek 385TH, 2018 EZGO TXR, 2005 Palm Beach 211 Bay, 2004 HD FatBoy.
02-20-2014, 07:21 PM
#226
Cosmo's Dad
I was told by my dealer to use dry graphite lube on the slide mechanisms. For the slide seals and other rubber seals around the trailer I use a slide out seal lube or 303 protectant. I use the 303 on the decals as well.
02-20-2014, 07:33 PM
#227
New 351 Owner
Congrats on the order. I think it was a good decision and welcome to the 351THSS family. I have measured and I believe I can get my EZGO and a Yam Griz 350 into the garage. A tight fit but pretty certain it will work. The Griz 350 is the narrowest full size ATV I can find based on all the maufacturer's web sites I have visited. Its a bit narrower than the Rancher I had but the Rancher and EZGO would not fit in the garage so the Rancher had to go. A real shame as I really liked the Rancher. Still shopping for the Griz.
Anyway, good luck with the new 351. I feel confident you will not be disappointed.
Here is to a great 2014 Camping Season! Giddyup!!
02-20-2014, 07:34 PM
#228
Congrats....you're going to like it. I just spent over 2 months straight in mine on it's maiden voyage. 3000 miles and more than 60 nights without a single issue!!!!
02-22-2014, 02:30 AM
#229
Hi what do they consider an Article package or a Rocky Mountain package. Coming from BC I need to have protection from freezing even while driving.
02-22-2014, 04:58 AM
#230
Cosmo's Dad
I have the Rocky Mountain package and it consists of an upgraded 35,000 btu furnace, extra insulation, enclosed insulated and heated fresh water tank, and black water tank flush out. I think it also has tank heaters on the gray and black tank as well.
02-22-2014, 11:28 AM
#231
What I was told by the dealer I just ordered mine from, Rocky Mountain =
Enclosed Underbelly
Heat Vent into Underbelly
Furnace Upgrade to 35,000 BTU
Heated Fresh Water Tank
Upgraded insulation
Black water flush kit
Additional tank heaters are available as an option.
03-24-2014, 09:01 PM
#232
Slide Lube
Finally got around to reading the manual again. What I found was in the Lippert slide mech manual. It specifically stated not to lube the mechanism. It does not really make a lot of sense as there are many great dry lubes out there. I have noticed my slide is squeaking a little this year so I may do a little research and give it a try.
Spring Break was a huge success again this year. Garner State Park was really hopping at the weekend dance at the pavillion. Loads of fun.
Here is to a really great camping season!
03-24-2014, 09:29 PM
#233
Cosmo's Dad
Hey rabraz, off topic, but I saw you mentioned Garner. I grew up in Uvalde so Garner was a weekly thing for us back in the day. How was the water flow?
03-25-2014, 07:38 PM
#234
Garner SP TX
Frio is flowing about the same as the last three years. Good enough to keep a line at the rope swings. Tubes float but have to portage a few areas. Really need a couple tropical storms to blow through the gulf and dump a couple weeks of heavy rain.
Still a good time was had by everyone. Thanks for asking Grooveman.
Here is to a great camping season!
04-15-2014, 10:18 AM
#235
Hey I have a question for you guys. I am having issue with birds making nest in the coupling area of the hitch. Do they make covers for that? I'm concern if a bird gets in there something else like a snake my go in there after the bird eggs. I think there was a conversation about this before on the blog.
Fred & Teresa
2002 EZGO Golf Cart
04-15-2014, 03:59 PM
#236
They do make pin box covers but personally I have not seen them and not sure if they would keep the birds out
doodler
04-15-2014, 04:16 PM
#237
Ok I have to come up with something. Thanks
Fred & Teresa
2002 EZGO Golf Cart
04-28-2014, 05:38 PM
#238
Hi from Havelock.
Anyone put a Reese's Goose box on a 356?
Sent from my SM-N900V using Forest River Forums mobile app
04-28-2014, 06:36 PM
#239
I have a 356 but have & would not put a goose neck adapter on it at least until the warranty runs out. It has a very heavy pin weight & will put a lot of stress on the frame which is not designed the same as a goose neck.. I went the opposite way & have a car hauler with a fifth wheel hitch.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
04-29-2014, 07:11 PM
#240
I'm installing the Reese 9622 goose box
