Old 06-16-2013, 08:29 PM   #21
You can see in the first picture there are two different stop switch locations, I moved mine up where you can see those screws. Be sure to remove both stop screws. I missed one and bent the rail at he other screw.
One of the other things I might try if needed will be to move the complete system up if I can verify there to be enough framing.
ID:	33402   Click image for larger version
TheGoodwin4 is offline   Reply With Quote
Old 06-16-2013, 08:39 PM   #22
I've got the lower bed out but here is a look at where the brackets are with the beds fully raised. Be sure if you raise the stop switch to make sure the bed is out of the way of the motor.
ID:	33404   Click image for larger version
Old 06-16-2013, 08:41 PM   #23
FandRChambers's Avatar
Trying to make out from your picture where the stop switch is you moved.
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 06-16-2013, 09:03 PM   #24
Stop switch is below the motor inside of the track.
Old 08-11-2013, 02:28 PM   #25
Cosmo's Dad
grooveman's Avatar
I just moved the stop switch up on mine and I ALSO forgot the screw on the other side of the track. Broke the screw and a piece of the screw wedged in between the bracket and rail. Managed to get it loose after hammering on the bracket. I was planning on taking the top bunk out but after that happened I just decided to leave it in.
Did manage to gain a bit more clearance under the bunks tho..
2012 Puma Unleashed 356QLB
2012 F350 Lariat Diesel
2-2011 Honda Rancher quads
1- Spoiled Rotten English Springer Spaniel
grooveman is offline   Reply With Quote
Old 08-14-2013, 09:02 AM   #26
Installing video cables to front bedroom.
I finally found the route for the video cables to the front bedroom. When I had to replace the cover over the bathroom vent, I found the routing under the vent moulding.
I am going to install my HDMI and video cable by going through the bathroom.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 08-14-2013, 10:19 AM   #27
Rear patio
We added a rear patio to TH. We put two jack stands to support the rear deck, a step ladder, and used the ramp locking rails as a hand rail for the patio.
You do need to be a little careful at the but it is still nice on cool days.
Old 08-14-2013, 04:24 PM   #28
Nice NG2951,
I thought about trying something like that but was afraid my door would not handle the weight.
Fred & Teresa
2002 EZGO Golf Cart
Old 08-14-2013, 04:35 PM   #29
Camper Less Camping
Cajun Po-Boy's Avatar
Creative patio mod!
That's the most appealing aspect to me with the larger TH...the rear ramp patio with fence & awning, nice extension on indoor space
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-21-2013, 02:06 PM   #30
Keyed Switch On Bunk Beds for Child Safety
We picked up a lightly used 2013 Puma 351 last week and I'm already making mods before our first trip. My kids are now 5 and 7, so they love to push buttons, to keep them safe when my head is turned I replaced the standard rocker switch for the power bunks with a keyed switch. I transferred the keyed switch from our old Travel Trailer to the 351, that is why the cover plate is Brass.
I bought the keyed switch on Amazon and figured out the correct wiring using an ohm meter then soldered the wires and crimped on spade connectors. I filed the Brass cover plate slightly to fit the keyed switch and used a piece from a box to fill in the gaps above and below the switch. I then pulled off the factory rocker switch and installed my spade connectors.
In the next few weeks I will be installing a master keyed switch and required high amp relays in the kitchen to kill power to the slide, awning, and power bunks. That will eleminate the need for this setup, but I though I'd share anyway.
IMAG1688 by Bluefinger222, on Flickr
IMAG1703 by Bluefinger222, on Flickr
IMAG1707 by Bluefinger222, on Flickr
bluefinger is offline   Reply With Quote
« bathroom storage | - »
