Old 08-21-2013, 02:21 PM   #31
Raising the Power Bunks
Like others I needed to move the rear bunks up to fit some taller toys. As others have done I moved the limit switch to the next highest setting, this gained me 2.5 inches, going from 69" to 71.5" at the bottom of the bottom bunk, just enough for a none lifted golf cart. In the future I will be flipping the side brackets or adding spacers to gain a couple more inches. Also, we won't be using the top bunk, so I'll remove the top matress when necessary to clear the A/C unit.
Warning, don't forget to move the two stop screws on either side of the rail right next to the limit switch. I didn't find any stop screws or obstructions on the other rails, but it would be a good idea to look carefully to avoid any damage.
Original height
IMAG1683 by Bluefinger222, on Flickr
New height
IMAG1684 by Bluefinger222, on Flickr
Limit switch in original location (screws loosened)
IMAG1677 by Bluefinger222, on Flickr
Close up of the actual limit switch
IMAG1678 by Bluefinger222, on Flickr
Limit switch in the new location (2.5" higher)
IMAG1676 by Bluefinger222, on Flickr
"Stop" screws that also need to be moved. You can see in this photo that the limit swich has been moved up, but the stop screws have not been moved yet. There is another screw on the other side of the rail.
IMAG1679 by Bluefinger222, on Flickr
My square bit driver for moving the "stop" screws, I had to open the rear ramp door to get enough clearance on the back side of the rail
IMAG1681 by Bluefinger222, on Flickr
bluefinger is offline   Reply With Quote
Old 08-21-2013, 02:40 PM   #32
Flipped Bathroom Door on Puma 351 - allows bathroom acces with slide in
Our kids are 5 and 7, so we make a lot of pit stops while on the road. The only flaw in the Puma 351 from our perspective was the inability to access the bathroom without opening the slide. Otherwise the floorplan and price point were perfect for us.
I originally considered installing a bi-fold door, but after looking a the diminsions I decided to flip the bathroom door upside down.
I removed the bathroom door (leaving the hinges on the door) and flipped it top to bottom. I then supported the door at the proper height and with the hinges properly aligned against the door jamb and installed the screws in the hinges. I then closed the door to check the fit. I closed the door and opened it a few times and determined the location of the striker plate, I screwed it to the door jamb and double checked it's location. I then cut out the plastic door jamb and a little bit of the wood with a 1/2 inch wood chisel so the striker plate would sit flush and then screwed it down.
This allows the door to open out, but with with the opening towards the garage. When the slide is closed there has always been enough clearance to open the garage door fully, now we can also open the bathroom door enough for even an adult to enter and exit.
There are some old screw holes left in the door jamb, but you don't really notice them unless you are looking for them.
Looking from the garage through the garage door at the slide and newly installed bathroom door.
IMAG1693 by Bluefinger222, on Flickr
Looking from the garage at the open bathroom door (with the slide in).
IMAG1692 by Bluefinger222, on Flickr
The middle hinge installed over the old striker plate hole.
IMAG1696 by Bluefinger222, on Flickr
The new striker plate hole on the opposite door jamb.
IMAG1700 by Bluefinger222, on Flickr
Old 08-23-2013, 09:03 PM   #33
FandRChambers's Avatar
Has anyone upgraded their light bulbs inside their unit to LED lights? If so how do you like it, where did you get them, and what size you get? Thinking about upgrading mine. Thanks in advance
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 08-23-2013, 09:43 PM   #34
Cosmo's Dad
grooveman's Avatar
We do a lot of dry camping so I changed out all the lights in the bedroom, bathroom & living area with LED's, as well as the porch light. Made a HUGE difference in power consumption. The lights are nice and bright but not too bright. I ordered most of them from a seller on eBay, 2011LED is the user name. They come from China but the shipping was fast, and the guy sent me the correct connectors at no charge when I ordered the wrong ones.
I am using the 48 LED bulbs in the overhead fixtures, If you need additional details on the exact bulb types etc let me know.
2012 Puma Unleashed 356QLB
2012 F350 Lariat Diesel
2-2011 Honda Rancher quads
1- Spoiled Rotten English Springer Spaniel
grooveman is offline   Reply With Quote
Old 09-01-2013, 07:59 PM   #35
We may have spoken about this before, but has anyone added a ladder to their unit? Thinking about adding one in the off season unless I find an alternative that's easy to haul, like one that breaks down enough to put on back of the truck without taking up too much space.
Fred & Teresa
2002 EZGO Golf Cart
Old 09-12-2013, 04:26 PM   #36
Cosmo's Dad
grooveman's Avatar
This was my project for my last day of vacation. We wanted more space to hang clothes when we were parked or when we traveled without the toys in the back. I found this collapsible closet rod system on Amazon. It folds flat against the wall to allow clearance for the bunks.
Old 09-12-2013, 09:10 PM   #37
kfp673's Avatar
great thinking! Great use of space!
kfp673 is offline   Reply With Quote
Old 09-18-2013, 08:59 PM   #38
Tomcat251's Avatar
Originally Posted by pjones1969 View Post
How about a thread about modifications you have done to your Puma Unleashed Toy Hauler
I've done several which I'll post later, I'll start with my latest.
patio ramp door completed yesterday
We have been looking at making the same mods to our new Puma unleashed SBU27, I have questions. First, how are you securing your bike? We have an 09 ultra. Second, how do you close your ramp door with the top eyebolts in place, or do you remove them?
Tomcat251 is offline   Reply With Quote
Old 09-18-2013, 09:33 PM   #39
pjones1969's Avatar
I was (I say that because I recently sold my Puma and bought a bunkhouse 5er) using the B&W Biker Bar http://www.turnoverball.com/products/motorcycle , its a great mount and held my 09 FLHX solid, you won't be disappointed.
The eye bolts actually were right outside of the door when it was up, I used the truck bed anchor point tie downs from Home Depot http://t.homedepot.com/p/Keeper-Blac...5652/203432519 , they have chrome also. They are 3/8" threaded so I used some all thread and drilled through the 2" square tubing that frames out the ramp door opening and bolted through that, the rubber seal on the door was right on the edge when the door was up, the cables were from WalMart http://www.osh.com/eng/product/brink..._cable/6810725 , this is it, couldn't find it on their site, the bottom eye bolts are called bed bolts, I got those on Amazon http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 , I turned them upside down and used a stainless washer and cap screw on the outside to "sandwich" that between the aluminum ramp door frame and sealed everything with silicone.
Zoom in on this pic and you'll see the anchor point on each side of the ramp door
Hope this helps!!
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 10-02-2013, 08:25 AM   #40
Originally Posted by FandRChambers View Post
Nice NG2951,
I thought about trying something like that but was afraid my door would not handle the weight.
I pretty much figured that since it would have to handle some kind of toy plus its driver, it should be able to handle up to 4 adults nad still be around that weight.
In reality, you only have about enough space for two adults and some kids.
What you need to be aware of are the sharp edges on the top of the ramp. You need to put some blocks on those so someone does not cut themselves on it.
What I found really surprising is that with the door down on your typical campground picnic table the door is almost level. You can use the table as steps and lets you setup/close your patio in seconds.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
« bathroom storage | - »
