Old 03-31-2013, 09:37 PM   #1
FandRChambers's Avatar
rear beds lower during transport
I took my 351 out for the first time. When i arrived to the campground the beds had come down on top of my golf cart. My last TH had pins to prevent this. This one doesn't. Happened to anyone else?
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 04-01-2013, 08:17 AM   #2
I have only took 1 trip so far but i did not experience this issue. So far so good.
ncamilli is offline   Reply With Quote
Old 04-01-2013, 08:35 AM   #3
Fred - one thing i do notice in your signature is that you tow with a 3500 dually. These 351's have a light tongue weight of ~1600 pounds and with a golf cart loaded up (guessing ~600 lbs) I would imagine the ride in the back of that camper is pretty bouncy and this could be part of your problem. I tow with a 2500 crew cab single wheel and with (2) atvs in the rear i noticed this immediately. I could only image with a 3500 dually. For this reason i am seriously considering investing in a Reese 5th Airborne King Pin to smooth out the ride for the toy hauler and me. Just some info i thought i would share.
Old 04-01-2013, 08:50 AM   #4
Thanks, but this also happened when i was empty, on the way to load up. But good point, also read someone else talk about filling the fresh water tank to level that off.
Fred & Teresa
2002 EZGO Golf Cart
Old 04-10-2013, 09:35 PM   #5
jonnys_walkers's Avatar
Your beds are electric, are they not? They should not come down unless the switch is activated.
We have the electric bunks in our toyhauler and we travel some pretty rough gravel roads and have never experienced a bunk moving.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-10-2013, 09:39 PM   #6
They never came down on my previous TH. Do you have the Puma 351?
Fred & Teresa
2002 EZGO Golf Cart
Old 04-10-2013, 09:40 PM   #7
Oaklevel's Avatar
On the end of the motor (above the top bunk) there is a switch that allows the beds to come down if it is not in the correct position. It is labeled. Check & see if it is not in the correct position...... Mine did that when I brought it home but now has never don it since.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 04-10-2013, 09:53 PM   #8
Thanks...i will check that.
Fred & Teresa
2002 EZGO Golf Cart
Old 04-13-2013, 06:41 PM   #9
Found switch....should it click up or down? It was up i clicked it down. Thanks
Fred & Teresa
2002 EZGO Golf Cart
Old 04-13-2013, 06:44 PM   #10
Switch was off...clicked it on. Thanks guys!!
Fred & Teresa
2002 EZGO Golf Cart
