MTGunner:
There should be a wiring diagram similar to this if you remove the outside door:
To the right in the pic above is the model number sticker. Here it close up:
The model number may also be in other places, but you may need to open it up and look inside where the control panel is.
At this point, we don't know your model #, but it's very likely one of the ones covered by the docs I'm attaching below.
Any fridge larger than about 3 cu ft will only be 2 way. Trying to power the cooling cycle with 12VDC for anything bigger than 3 cu ft uses WAY more power (i.e., current) than your tow vehicle can supply through the usually skinny wire to your 7-way hitch plug.
