Old 05-03-2017, 10:43 AM   #1
Slide Topper
Has anyone added a slide topper to their Puma Unleashed 356qlb?
were there any problems with the installation?
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
Super8mm is offline   Reply With Quote
Old 08-08-2017, 07:45 AM   #2
Triple S Kennels's Avatar
I would like to know the same thing?
Triple S Kennels is offline   Reply With Quote
Old 08-08-2017, 09:10 AM   #3
Kasual Kamper
We just purchased and installed the Lippert slide topper on our MicroLite 21DS this past Saturday. It was a bit of a pain in the arse to get the brackets connected, even though there is a good YouTube out there showing you what to do. We had a difficult time getting the rods inserted once the brackets were in place. However, once we accomplished it, everything worked perfectly and the product seems to be of good quality.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 08-08-2017, 03:22 PM   #4
Did you have problems finding studs to attach it to?
2013 Puma 356QLB
Days Camped 33
Miles 6450
Old 08-08-2017, 03:46 PM   #5
Kasual Kamper
I didn't worry about it. The awning rail uses 12 - 15 screws and the brackets each have 5, so there's plenty to grab on to. None of the instructions mentioned studs either. You don't have much choice anyway. The awning has to be placed where it has to be placed.
Old 08-08-2017, 04:05 PM   #6
Briorick's Avatar
We just purchased and installed the Lippert slide topper on our MicroLite 21DS this past Saturday. It was a bit of a pain in the arse to get the brackets connected......We had a difficult time getting the rods inserted once the brackets were in place. However, once we accomplished it, everything worked perfectly and the product seems to be of good quality.
Our experience as well......we recently installed a slide topper on our Cruise Lite over the dinette and, as you mention, we had the same problem fitting the rods into the bracket holes.
What we found was that we had to file a bit off the outer perimeter of the rod ends ( paint build up ). Once we figured that out, the rod ends went in smoothly. We then touched up the filed rod ends with some black paint. Walah...works like a charm!
Other than the paint build up on the rod ends, the slide topper was a breeze installing.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 08-08-2017, 04:15 PM   #7
Kasual Kamper
I also found that a little bit of WD-40 and a hell of a lot of pounding with a rubber mallet helped.
Old 08-08-2017, 04:23 PM   #8
Briorick's Avatar
Sometimes you just gotta....MAKE iT WORK!!!!!!!!
Rick & Brian
slide
