Old 05-30-2012, 05:55 PM   #1
Slideout Binding on Puma Unleashed 356QLB
We have a 2011 Puma Unleashed 356QLB toy hauler that we're having trouble with the slideout binding up. When we attempt to slide it, the right side(the side with the actuator) moves quicker than the left (the rear closer to the garage). My husband has already replaced the square piping under the slideout because it cracked at the seam. The slide out worked a few times in and out, but then it returns to moving uneven again. The unit is sitting level and the gears are good. Has anyone had issues with their slideout, or any suggestions with how to correct our issue? Thanks.
hillbilly4rd is offline   Reply With Quote
Old 05-30-2012, 05:58 PM   #2
TURBS's Avatar
carpet catching ?
Old 05-30-2012, 06:19 PM   #3
No, doesn't seem to be the carpet. Appears to be something fetching up underneath.
Old 08-14-2012, 05:32 PM   #4
Poppy94's Avatar
did you find it? i can look at mine operate but without knowing what/where yours is hanging up, i won't be able to tell you what should be normal. let me know. i'll help you out. mine TH is identical to yours.
Poppy94 is offline   Reply With Quote
