Old 04-17-2013, 12:44 PM   #1
Cosmo's Dad
grooveman's Avatar
Water lines under Puma 356?
Hey all. I was looking under my Puma 356 today getting ready to start the spring maintanence and I noticed what appeared to be two capped water lines, one red and one white coming out from the floor and protruding about 12" or so near the dump valves. Anybody know why they are there?
I have the Rocky Mountain package also.
grooveman is offline   Reply With Quote
Old 04-17-2013, 12:44 PM   #2
TURBS's Avatar
Low point drains for winterizing.
Turbs
Old 04-17-2013, 01:41 PM   #3
Cosmo's Dad
grooveman's Avatar
Man I completely missed those. I went through the steps recommended by the dealer for winterizing, running pink stuff through all the lines etc.. but I didn't drain those. Hope it didn't mess anything up.
Old 04-17-2013, 02:28 PM   #4
TURBS's Avatar
Most likely not .... but here's hoping all is well!
Old 04-25-2013, 08:53 PM   #5
Oaklevel's Avatar
I have the 356 as well all should be fine........... Yes they are the hot & cold line drains & If I remember correctly there is one under the fresh water tank as well........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-28-2013, 03:54 PM   #6
Poppy94's Avatar
i just blow mine dry with an air compressor. don't that pink stuff stink? ain't it hard to get out of the system? a buddy of mine told me not to use it as he took about a month of solid flushing to get it out of his system. so i've never used that stuff and i haven't had any issues at all.
Poppy94 is offline   Reply With Quote
Old 04-28-2013, 04:00 PM   #7
TURBS's Avatar
Flush with bleach one time and Its good.
Old 05-01-2013, 10:18 AM   #8
Poppy94's Avatar
hey my friend, would a 50/50 mix do it?
Old 05-01-2013, 10:21 AM   #9
TURBS's Avatar
50/50 what?
If you mean bleach ratio 1 cup of bleach per full water tank will be plenty.
And you should do this regardless of using antifreeze or not.
Turbs
Old 05-01-2013, 10:30 AM   #10
Poppy94's Avatar
50/50 what?
Turbs
yes sir, the bleach ratio. wow, i guess i've been overdoing it on the fresh water circulation cleaning cycle at the first of the year each year. ummm.....guess i underestimated the power of bleach! . thank you so much for the advice.
