Old 08-10-2013, 04:39 PM   #1
Robdog66's Avatar
05 Sandpiper Sport 37SP water leak
I have two fresh water tanks that are connected together with a common drain valve, the threaded fittings that are glued to the bottom of the tanks are cracked and leaking. Are these readily available at an rv store or where would I be able to find them? Thanks, Rob
Robdog66 is offline   Reply With Quote
Old 08-17-2013, 12:12 AM   #2
Robdog66's Avatar
This is where I found the fittings I need, great company to do business with if you need tanks or fittings. Now I will try my hand at spin welding tomorrow!
Home
2005 Sand Piper Sport FW37SP
2001 Ford F-350 crew 4X4 7.3
2006 Jetta TDI
leak, sandpiper, water, water leak
