Old 04-04-2013, 02:29 PM   #1
hotshott's Avatar
07 Montana 5thwh. NASTY water.
A friend of mine owns the above mentioned trailer. His water whether park hook-up or fresh storage is absolutely nasty. He uses an in line filter as well as under cabinet whole unit filter. They are changed on a regular basis. This weekend I am going to attempt a complete water system flush out with 50/50 bleach and water mixture. This includes the entire fresh water system and tank, Grey water system and tank and the black water tank will get a flushing out as well. The hot water heater and all valves are under a cabinet in a very tight area. The water lines are NOT color coded and I have a feeling that he mite have managed to allow some old stale water from fresh water tank into the rest of the system by playing with the valves. The camper is in a seasonal site and does not get moved. I am hoping that my flushing the system will do the job. I do not have any manuals however I know which valves need to be open and closed as needed. ANY suggestions will be greatly appreciated. also need to mention that the roof vent is not obstructed. His black and grey holding tanks have the stirring blades but are not used due to his lack of knowledge on their significance.
TT. 2011 Salem Grand Villa.
TV. 2009 F350. Dually, Lariat, Twin Turbo (after market)
w/ stock exhaust and Maramount Easy-flow muffler.
hotshott is offline   Reply With Quote
Old 04-04-2013, 02:31 PM   #2
TURBS's Avatar
Rotten egg smell?
Old 04-04-2013, 02:37 PM   #3
hotshott's Avatar
Originally Posted by f1100turbo View Post
Rotten egg smell?
I am sure that at one time it was. However, It has gotten worse. Almost smells like sewage. And I am a plumber for 38 years. Carl is an older guy and does not maintain as he should,, This is where I come in. I love the man and don't want to leave him hang. Besides, he mows my 1/2 acre,, no charge..
Old 04-04-2013, 02:39 PM   #4
TURBS's Avatar
http://www.motleyrvrepair.com/water_heaters1.htm
Just an fyi
Old 04-04-2013, 02:40 PM   #5
hotshott's Avatar
Rotten egg smell?
He has the 6 gallon hot water heater and the anode rod has been removed in lieu of the sediment filter.
Old 04-04-2013, 02:42 PM   #6
hotshott's Avatar
Water Heaters
Just an fyi
Thanx for the link. I can copy any pertinent material and tag it along for the ride. I would like to thank f1100turbo for sending me a beautiful link to aid in this dilemma.. I will post results next week. I have owned campers for years. I am not na´ve to maintenance and repair. However after we reach a particular age, It's nice to watch someone else make the repair for you. I am not there yet.
Old 04-04-2013, 02:43 PM   #7
TURBS's Avatar
Your welcome! Good luck.
As you stated before a healthy dose of bleach will definitely help!
Turbs
Old 04-04-2013, 02:58 PM   #8
MtnGuy's Avatar
That is a pretty strong solution of bleach. The usual recommendations is 1/4 cup to every 15 gallons of water.
