Old 08-31-2016, 08:29 AM   #1
14' fr3 fresh water leak
What component is this that's leaking fresh water?
2014 FR3 25DS
teamjendy is offline   Reply With Quote
Old 08-31-2016, 10:21 AM   #2
pashooter's Avatar
Photo shows the hydraulic reservoir & pump... where's the "water leak"?
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2019: 76
pashooter is offline   Reply With Quote
Old 08-31-2016, 10:25 AM   #3
Thanks for the reply. The leak is coming from the holes circled in the attached photo.
Name:	Screen Shot 2016-08-31 at 10.23.49 AM.jpg
2014 FR3 25DS
Old 08-31-2016, 10:29 AM   #4
Are you sure it is 'fresh water'?
Hydraulic fluid (like would be in the plastic reservoir above the holes) is clear liquid. (oil)
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 08-31-2016, 10:32 AM   #5
I'm not 100% sure. I'll have to check when I get home. I should also mention my levelers don't work ... never have. The leveler controller just blinks all the lights...
2014 FR3 25DS
Old 08-31-2016, 10:32 AM   #6
pashooter's Avatar
Yeah... I suspect you're leaking hydraulic fluid. Maybe from where the pump mounts to the reservoir?
The flashing lights may be an error indication of a low fluid condition.
Old 08-31-2016, 12:32 PM   #7
Do you know where i would fill this fluid and what type of fluid it takes? Is it just a general hydralic fluid that I can get at auto store or something specialized/specific to the RV?
2014 FR3 25DS
Old 08-31-2016, 01:11 PM   #8
pashooter's Avatar
There should be a cap on top of the reservoir but it looks like the way yours is mounted it may be hard to get to. Did you not get a manual or any paperwork for the system? Have to identify exactly what system you have to determine what type of fluid to use, but I believe most use standard ATF (automatic transmission fluid) available at any auto parts store.
Here's the manual for the one that came on my Pursuit.
http://www.lci1.com/assets/content/s...r_s_Manual.pdf
Old 09-01-2016, 01:34 AM   #9
I got under there today. It's definitely fresh water leak coming from above the hydraulic system you mentioned. Is the fresh water tank located above it? I can't seem to locate the leak source.
2014 FR3 25DS
Old 09-01-2016, 01:47 AM   #10
pashooter's Avatar
Glad it's not a hydraulic system problem. Sorry, I can't help finding your fresh water leak, as your FR3 is laid out differently than my Pursuit (there are no tanks or plumbing anywhere near my pump & reservoir) - will have to hope an FR3 owner more familiar with the layout of your rig chimes in at this point. Good luck!
fresh water, leak, water, water leak
