Old 08-10-2016, 11:00 AM   #1
Austintatious's Avatar
17FQ Fresh Water Tank Filling Up While Connected To City Water
This appears to be a common issue. After more than 30 nights of no trouble, on this outing I found our freshwater tank is now filling up while connected to city water. At first it was only a third of a tank after two days but it's gotten progressively worse where now it's filling up in just 24 hours.
I've read about checking/cycling/repairing the pump or even adding a check valve but I'm considering a simple shutoff valve since I will seldom use the freshwater tank.
Any possible issues with adding a 1/2" PTC shutoff valve? I have no problem reaching under the sink cabinets to turn it on should I ever need to use that tank, but on what side of the pump should it be installed or does it even matter?
2016 Clipper 17FQ
2016 Ram 1500 EcoDiesel
2015 Jeep Wrangler Unlimited
Austintatious is offline   Reply With Quote
Old 08-10-2016, 11:57 AM   #2
Like this? I put the valve on the output side of the pump.
Name:	pump cutoff.JPG
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 08-10-2016, 12:00 PM   #3
Exactly! Thanks.
2016 Clipper 17FQ
Old 08-10-2016, 12:54 PM   #4
Well I just pulled the access panel and to my surprise there is already a cut off on the input side of the pump. Actually it looks to be a winterization tap but it will work nicely to shut off the freshwater tank when not in use. Also surprised to see so many spare parts laying around in there
I'm going to modify the panel for easy access and make some good use of all that wasted space.
2016 Clipper 17FQ
Old 08-10-2016, 01:00 PM   #5
Flybob's Avatar
Be careful. If the valve is a winterizing valve and you turn it to the winterizing position to shut off the tank you will be opening the valve to the pigtail that goes into the antifreeze tank. If the pigtail does not have a good seal on the end and the back flow valve in the pump is stuck, you will flood the floor of the RV with water coming out of the pigtail.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-10-2016, 01:11 PM   #6
Understood. The pigtail is capped and I plan on making sure it's tight and sealed properly.
2016 Clipper 17FQ
Old 08-10-2016, 01:33 PM   #7
What Flybob says is correct (as always). That is why I installed a separate valve. The reason (my own, no empirical evidence) is that I don't want the 55 psi water pressure constantly present in the pump housing while on city water. I figured by eliminating that pressure in the pump it eliminates a few more spots where a gasket or something could fail resulting in a leak. Does that make sense?
Lee and Anne
Old 08-10-2016, 01:48 PM   #8
That makes perfect sense. When I get home I'm going to relocate the pump because access to the output side is a little awkward right now and then I'm going to add the cutoff on the output side. I can see how the filter attached on the vacuum side is also a weak point.
2016 Clipper 17FQ
city water, fresh water, tank, water, water tank
