Originally Posted by ChuckP
OK thanks - where's the water filter? As far as I know I don't have one. If you mean the screen where the water supply hooks up, I did take that out for a try, but no change.
The exact location of the filter varies some from model to model. In mine, and in most I've seen, it is located near the water pump. If you don't know where the pump is, put some water in your fresh water tank, turn on the pump switch, open a a faucet, and you will be able to locate it by the sound it makes.
