Originally Posted by djc2jr
I checked the sink and shower drain pipes which I access through the door on the left side of the front storage compartment. About 4 inches from the shower drain is the rear wall of the storage compartment. I moved around some of the things in the storage compartment and caught sight of a screw in the wall. I moved more things and found my access panel to the water heater. The water heater is under part of the shower, but is accessible through the front storage compartment. I have the one valve bypass system which has the check valve on the hot water line. Thanks for your help.
I'm assuming when you say "one valve bypass" you mean that valve is a 3-way valve. If it's just a standard valve, then you need to find your cold water inlet valve.
In other words, I'm assuming you mean you have option #4, not option #5, on page 2 of the attached plumbing pic. If you have option #5, you need to find the other valve.
2011 Traverse LT, 3.6L, FWD
