Old 06-20-2009, 11:49 PM   #1
2009 Sandpiper 351BHT water filter location
Does anyone know where the water filter is located on the 2009 sandpiper, model 351BHT? I can't seem to find it.
Thanks for your help.
jjkalmus is offline   Reply With Quote
Old 06-21-2009, 06:13 AM   #2
I have a 2009 345RET and mine is in one of the the lower kitchen cabinets, There is a piece of paneling with two screws holding the paneling in place hiding the filter, Also if you turn on the water pump and and listen your filter will be with the pump.
Now maybe you can help me, On the monitor panel what is the red rocker switch the says HTR for, I know it probable stands for heater but my water heater works weather it is on or off.
I think Forest River could of come up with a better owners manual.
Dave
Davet is offline   Reply With Quote
Old 06-21-2009, 06:44 AM   #3
It may be your holding tank heaters
SwensonBarrettBunch is offline   Reply With Quote
Old 06-21-2009, 08:03 AM   #4
highwayman's Avatar
Water Filter is under the bathroom vanity in my 2009 Sandpiper RDL 332.
Thin sheet of paneling hiding it form view.
Location is terrible by the way!
highwayman is offline   Reply With Quote
Old 06-21-2009, 03:26 PM   #5
That is a tank heater
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 06-21-2009, 04:18 PM   #6
tripstowin's Avatar
Mine is under the bathroom sink,
2008 SIERRA 351BHT
tripstowin is offline   Reply With Quote
Old 06-22-2009, 12:34 PM   #7
The switch you are refering to is for the winter heaters for your holding tanks. I asked the same question at my dealership when I took delivery of my 345 RET. Normally you won't need it unless you are over winter user.
BCurrens is offline   Reply With Quote
Old 06-22-2009, 12:35 PM   #8
Thanks for the location of the filter on the 345 RET I talked with Forest River and they told me that it was located under a removable panel inside the cellar??? I'll check out your answer too.
Old 06-22-2009, 02:43 PM   #9
We are taking delivery of our new 2010 Sandpiper 356RL this Saturday (June 27th) from RV Wholesalers in Ohio, we can't wait. Trading in our 2006 Keystone Outback 30FRKS for the Sandpiper.
Carey & Theresa & 3 dogs Lucky, Shannon & Coco
TV 2006 Dodge Ram 2500 Big Horn Quad Cab 4x4 w/5.9 CTD DrawTite 16K Double Pivot Slider Prodigy Brake Controller
5er 2010 FR Sandpiper 356RL w/Satin interior Signature Package
CTDSandpiper is offline   Reply With Quote
Old 06-22-2009, 10:45 PM   #10
on my wall panel (351BHT) the HTR switch is to turn the how water heater propane heating function on. This way your hot water heater will run off electric and gas so it will replenish your hot water faster. But this is for my model so yours may be different.
