Old 04-09-2019, 01:43 PM   #1
RandK-M's Avatar
2109s - Question about water lines to freshwater tank
I'm getting ready to de-winterize and sanitize and was looking at the fresh water tank and I see I have 3 lines to the tank plus the drain line on the bottom. I never noticed the 3rd line near the top before.
One is the large corrugated freshwater fill, then there is the 1/2" line on the side toward the bottom of the tank which must go to the pump suction side to supply the camper. But what is the 3rd 1/2" line that enters the tank near the top? I was trying to trace the lines in the pass-through storage, but they go up inside under the bed nightstand area where I can't see them.
I was thinking it may be some way to fill the tank while using the city water hookup since it's near the top of the tank, but I don't see any valves for that. The only valve I have anywhere around the pump and water lines is on the suction side of the pump which is for the antifreeze inlet I think.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
Old 04-09-2019, 02:26 PM   #2
Aeronaut's Avatar
My 2019 has a water diverter in the shower to conserve fresh water. It allows the return of water to the fresh tank. And yes you can use it to fill from city water.
2019 Tundra 5.7 4x4
2019 Rockwood Mini Lite 2109S
Aeronaut is offline   Reply With Quote
Old 04-09-2019, 02:28 PM   #3
Overflow/vent?
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 04-09-2019, 03:08 PM   #4
RandK-M's Avatar
I don't think I have a diverter like that, just a regular shower faucet.
2017 Rockwood 2109S
Ram 1500
US Navy Veteran
Old 04-09-2019, 04:12 PM   #5
Aeronaut's Avatar
Perhaps it was optional and Pre plumed?
2019 Tundra 5.7 4x4
Old 04-10-2019, 02:46 PM   #6
Yes I bet that’s your vent; at least on my 233SS it is the vent. As it fills with water, the air has to go somewhere...
By the way, if you trace it it should trace back to the upper portion of the city filler port where the air hole is..
CyclePilot is offline   Reply With Quote
Old 04-10-2019, 04:40 PM   #7
Overflow/vent?
Yes, this...what 5picker said.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 04-10-2019, 06:39 PM   #8
Vent/overflow. Fill your tank until it reaches the pipe at the top of the tank. When the water flows into that pipe you should see water start to flow out under the trailer.
markb422 is offline   Reply With Quote
Old 04-10-2019, 06:59 PM   #9
RandK-M's Avatar
Thanks everyone, I bet it does connect to the vent that has the little screen on it by the tank fill cap. I should have thought of that myself!
Ray
2017 Rockwood 2109S
Ram 1500
US Navy Veteran
210, 2109s, tank, water, water tank
