Old 08-18-2016, 11:13 PM   #1
242rlx water heater won't work
Hello all, my fiancÚ and I just bought a 16 wildcat maxx 242rlx. We're camping right now and the hot water doesn't work. Earlier I fires it up with the switch on and it lit. Tonight I wanted to take a shower and there's no hot water. We don't have any valves on the tank under the fridge access panel and both valves are closed on exterior shower. I ran the hot water for awhile on an inside sink to fill tanks hopping it would work and still doesn't. When I opened the water heater panel the drain valve is more than warm but still no water is coming out. All wires seem to be connected and the reset bottoms aren't out for me to reset. We are first time owners and need help!
Jbtownsend101 is offline   Reply With Quote
Old 08-19-2016, 01:36 AM   #2
Bako88fan's Avatar
Are you hooked up to campground electrical or are you running off propane and battery power?
2008 Wildcat 29RLS
2016 Chevy Silverado 2500 HD
4x4 z71 Crew Cab Duramax/Allison
Bako88fan is offline   Reply With Quote
Old 08-19-2016, 05:26 AM   #3
wmtire's Avatar
You most likely have the bypass valves incorrect. These valves are most likely BEHIND your hot water tank, if you don't have a plumbing station. You will need to find a way to access behind the tank. You may have to remove a false cabinet door, a drawer, a bed bottom, etc...in order to gain access to these valves.
Once you gain access and find the valves, then this thread may help:
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
Real men don't eat honey. Real men chew on bees.
Old 08-19-2016, 08:17 AM   #4
Head Rambler
I believe your MAXX has a plumbing station. That's where you water heater bypass valves could be.
Open it up and take a picture if you're in doubt and maybe we can tell you which is which.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-19-2016, 08:23 AM   #5
SeaDog's Avatar
Welcome to the forum as you will see this is a great place to get your questions answered, to bad your first post is with a problem, I agree with what others have said, if you are not sure take a pic and post it
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-19-2016, 10:33 AM   #6
We're running off both propane and battery and generators when needed.
Old 08-19-2016, 10:37 AM   #7
Thanks for all the replies. My phone won't let me load pictures on here but I found three valves in the passenger side storage compartment. Ones a red line coming from the heater tank thanks open, one then goes from that red line down to the blue line which is open and there is a blue line from the heater that's closed. And also how do you fill and check if there's water in your heater tank exactly?
Old 08-19-2016, 10:39 AM   #8
Nvm I just figured it out. I opened the one cold valve and closed what I'm thinking is the bypass line and it works perfectly now!
Old 08-19-2016, 10:42 AM   #9
wmtire's Avatar
Glad you got it working, as this is one of the more common problems and why we have the sticky link I posted at the beginning of this thread in post #3. You may want to bookmark if for future reference as it has the diagrams as how the valves are supposed to be.
Old 08-19-2016, 10:51 AM   #10
wmtire's Avatar
If you have a Suburban water heater this operational thread may help:
Suburban's electric switch and much more
heater, water, water heater
