Old 05-08-2016, 10:05 AM   #1
2716G De-winterize: Can't completely drain fresh water tank
What's the best way to empty out the fresh water tank? The drain spout is not positioned at the bottom and therefore leaves some liquid/antifreeze in tank. Is it a bad idea to jack up one side of the camper?
Thank you!
Campfam
2016 2716G pup
Sent from my SM-T350 using Tapatalk
campfam is offline   Reply With Quote
Old 05-12-2016, 12:45 PM   #2
pashooter's Avatar
Just leave the drain valve open when you head out on your first trip... assuming you're not going dry camping with a load of water onboard. The sloshing around from driving will finish emptying the tank as you go down the road.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2019: 76
pashooter is offline   Reply With Quote
drain, fresh water, tank, water, water tank, winter, winterize
