Old 01-24-2013, 07:41 PM   #11
dashonthedash's Avatar
Try some Alka Seltzer?
Seriously, though, what exactly is happening?
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 01-24-2013, 08:40 PM   #12
VinceU's Avatar
Any chance the gray tank is under the bedroom? In that case the piping from the bath would be flexible corrugated tubing which might pinch and restrict drainage.
Old 01-26-2013, 12:52 PM   #13
Gary, when we drain the kitchen sink the bath will burp then you have to wipe water off the mirror. It is raining today so i can't go on roof to check roof vent but I am assuming the roof vent is plugged. Before this started when you drained the kit sink you would hear like a rush of air about half way down now you don't.
63belv is offline   Reply With Quote
Old 01-26-2013, 12:53 PM   #14
Not sure of tank location have not been under to check but I will.
Old 01-26-2013, 01:06 PM   #15
B47
Originally Posted by 63belv View Post
I am going with Gary and say it is a dummy. The coach is wired for sat. and the location fits. Still have not solved burp. Thanks
Have you or could you run a snake in the drain? You may have a partial blockage caused by an object that is letting some air venting, but not all.
Old 01-26-2013, 01:11 PM   #16
Is the kitchen sink draining normally? Like B47, I was thinking of the possibility of a clog/blockage.
Old 01-27-2013, 09:47 AM   #17
sink drains ok but it seems when it gets to tank it vents through bath sink
Old 01-27-2013, 11:46 AM   #18
What happens when you drain the bath sink?
Old 01-27-2013, 07:38 PM   #19
The drain from the kit. sink has a vent pipe going up to the roof before it reaches the grey tank. No rain tomorrow and I will go up on the roof to make sure it is not plugged. Ot
