Old 01-22-2013, 12:48 PM   #1
3 vent caps on roof
Having trouble with grey tank vent getting a burp in bath sink. While on the roof checking vent I have 3 caps 1 I would say os right side is black tank 1 on left looks to be grey tank bothright above bath area. Now there is 1 just in front of entry door and I see nowhere that is comes through ceiling or goes down the wall, what could it be? On the burp problem I have already changed both plumbing vents under the sinks. Thanks
63belv is offline   Reply With Quote
Old 01-22-2013, 01:08 PM   #2
Herk7769's Avatar
I am not familiar with your layout. It is possible that in your camper the sink does not have a vent that penetrates the roof. Look under the sink for a "ventless" air break that may be stuck closed.
If you have one and it sticks, they are very easy to replace (they unscrew) and very inexpensive.
NEW OATEY 39012 USA MADE BLACK ABS AUTOMATIC VENT PLUMBING AIR ADMITTANCE on eBay!
Air Admittance Valves from Oatey | The Home Depot - Model 39018
Name:	Air Admittance Valve.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 01-22-2013, 02:00 PM   #3
Herk, Already changed both of those kitchen and bath. My unit is a 359Xl and there is no plumbing in front of side door. The vent on the roof in front of door seems to go nowhere there is a cabinet there but no pipe showing inside and wall is not thick enough for pipe to come up through the wall. Thanks for your answer.
Old 01-22-2013, 02:14 PM   #4
dashonthedash's Avatar
It could be a dummy cap to cover access for a possible satellite mount. Do you already have a satellite dish or a pre-wired prep package?
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 01-23-2013, 09:05 AM   #5
dondash Thanks it is wired for sat
Old 01-23-2013, 09:18 AM   #6
LaydBack's Avatar
Do you have a washer hookup up front?
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 01-23-2013, 12:00 PM   #7
It is likely that one of the vent caps is a dummy hiding the wiring access for the sat; that's how my coach is laid out.
Old 01-23-2013, 12:21 PM   #8
Send a message via MSN to Tiggerdad
Possible attic vent? My previous rig had them for that purpose.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 01-24-2013, 01:51 PM   #9
Dallas Texas
TexasBBQ's Avatar
Like Tigg.. said. I have 2 attic vents and 3 plumbing vents. When you replaced it what did you see?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 01-24-2013, 07:55 PM   #10
I am going with Gary and say it is a dummy. The coach is wired for sat. and the location fits. Still have not solved burp. Thanks
Old 01-24-2013, 08:41 PM   #11
Try some Alka Seltzer?
Seriously, though, what exactly is happening?
Old 01-24-2013, 09:40 PM   #12
VinceU's Avatar
Any chance the gray tank is under the bedroom? In that case the piping from the bath would be flexible corrugated tubing which might pinch and restrict drainage.
Old 01-26-2013, 01:52 PM   #13
Gary, when we drain the kitchen sink the bath will burp then you have to wipe water off the mirror. It is raining today so i can't go on roof to check roof vent but I am assuming the roof vent is plugged. Before this started when you drained the kit sink you would hear like a rush of air about half way down now you don't.
Old 01-26-2013, 01:53 PM   #14
Not sure of tank location have not been under to check but I will.
Old 01-26-2013, 02:06 PM   #15
B47
Have you or could you run a snake in the drain? You may have a partial blockage caused by an object that is letting some air venting, but not all.
Old 01-26-2013, 02:11 PM   #16
Is the kitchen sink draining normally? Like B47, I was thinking of the possibility of a clog/blockage.
Old 01-27-2013, 10:47 AM   #17
sink drains ok but it seems when it gets to tank it vents through bath sink
Old 01-27-2013, 12:46 PM   #18
What happens when you drain the bath sink?
Old 01-27-2013, 08:38 PM   #19
The drain from the kit. sink has a vent pipe going up to the roof before it reaches the grey tank. No rain tomorrow and I will go up on the roof to make sure it is not plugged. Ot
