Old 11-27-2018, 04:57 PM   #1
32 degree camping
Do you have to sanitize every time you use rv antifreeze?I usally drain everything and use the antifreeze in the drains and traps. most of the time we only hit the 30 degree temps about 5 times max.
tjjoyner is offline   Reply With Quote
Old 11-27-2018, 05:00 PM   #2
A32Deuce's Avatar
If just putting in traps and drains, no. Do you blow out the water lines and drain the tanks and filter housing?
A32Deuce is online now   Reply With Quote
Old 11-27-2018, 05:05 PM   #3
Flybob's Avatar
Sanitizing and rinsing out antifreeze are two different things usually accomplished together at the time of dewinterizing. If you have recently sanitized and are just rinsing out antifreeze, you do not have to do full sanitize procedure. Just rinse out good.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-27-2018, 05:20 PM   #4
new at this but I do drain and blow out everything and I do sanitize when needed.I have not used the antifreeze in my water supply yet but I would like to if I do not have to sanitize each time.
Old 11-27-2018, 05:57 PM   #5
You might also cut an access panel to your water pump area and use an oil filled heater. This will move warm air onto the water pump, in case there some water still in the pump.
Ram 2500 diesel / FR surveyor 251rks
debit is offline   Reply With Quote
Old 11-27-2018, 05:59 PM   #6
if you bring bottled water and are not drinking from your fresh tank I would not be worried so much.
Kimber45 is offline   Reply With Quote
camping
