Old 01-24-2014, 05:26 PM   #71
Originally Posted by RJHuser View Post
Do you have part numbers for the 140 Thermostats? Do you have to change the high limit thermostats also?
They depend on your particular water heater. The thermostat/high limit is one unit.
NOTE: The elec. spades are different sizes and on different sides. The one I got from Camping Connection was the large spade (I had to cut them down) and on the opposite side. I had a heck of a time getting it to fit. The ones I ordered are the correct ones
Mine is a Suburban SW6DE and the pn is Suburban Heater T Stat Switch Assembly 232317
Purchased two from Supply Parts for $42 including shipping.
Old 01-24-2014, 05:29 PM   #72
This my work---------------------
Suburban 232317 Water Heater Thermostat Limit Switch Optional 140 Degree 120VAC ID 2475 RV Parts
You will need one for high gas and ele limit
Try this one out. I changed my thermostats, plenty of hot water!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAISY BOYKIN is offline   Reply With Quote
Old 01-25-2014, 07:13 AM   #73
KyDan's Avatar
If I were going to turn up the heat with a new t-stat,
I'd probably just change the 120v AC one to 140 deg and leave
the LP as is.
WE usually camp with electric hookups so the rare times
we are off the grid we could live with 120 deg water via the LP burner.
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
show, shower, water heater
