Old 08-22-2016, 01:48 PM   #1
8329SS 2015 plumbing question
Just sold a 2014 Jayco and the plumbing was very straight foward, however under the bathroom sing in a mess of plumbing. Can't determine why there is a small shut off valve on one of the water lines. Can't figure out why there is a small tube leading from another line to the outside connections. cant figure out what values to use for winterization. HELP cuz the manual does explain or help.
Tcdoughboy is offline   Reply With Quote
Old 08-24-2016, 03:31 PM   #2
Unhappy valve at water pump intake
i also have this problem what does this valve do? 2016 8325SS please answer
RAYSR is offline   Reply With Quote
Old 08-24-2016, 03:48 PM   #3
Some pics might help.
2011 Traverse LT, 3.6L, FWD
Old 08-25-2016, 01:37 PM   #4
Here is photo I think?
Old 08-25-2016, 01:40 PM   #5
I now know how to up load photo
Old 08-25-2016, 01:49 PM   #6
Is this the same valve tcdoughboy?
Old 08-25-2016, 02:38 PM   #7
That valve is a 3-way valve on the suction of your water pump (blue line). The valve can chose to take a suction on either of the other two lines. One of these two lines should go to the bottom of your fresh water tank. The other one PROBABLY goes to an outside connection. If so, that's the connection you use for anti-freeze.
See the plumbing pic I've attached. Most RV's look something like it.
Old 08-25-2016, 05:04 PM   #8
Many thanks I think I under stand. This valve is turned to fill the lines with anti freeze and not the the fresh water tank their is also a valve to switch to a bucket of anti freeze. A total of 5 valves to turn when winterizeing 3 for bypassing the water heater one to add suction to antifreeze, any this valve to bypass the water tank and pump antifreeze thru all lines.
Old 08-25-2016, 09:00 PM   #9
I' m not aware of a separate valve for the antifreeze. Just the valve in your pic. And the 3 valves at your water heater.
Old 08-25-2016, 11:01 PM   #10
Valve is out side where hose is attached separate fitting for antifreeze and valve to suck up antifreeze also switch to turn on pump and light for working at night.what will they think of next?
plumbing
