The owners manual on these campers are EXTREMELY generic- not worth the paper used to print them. If your'e having trouble getting to sleep at night, then read one. Useless! Since you stated that you only use 12v power, and the camper is a 97, there is a strong possibility you have a bad thermostat. X2 on that probability. Make sure you don't have any wires touching ground on that solar array, also. Good luck, Randy
