Old 11-22-2017, 10:18 AM   #1
A lot of Scale In Suburban Water Heater
We have a 2011 Forest River V-Lite 30WKSS that we purchased used 2 years ago. Last year I noticed that there was a pretty good amount of white scale in the bottom of the water heater when I drained it. I got about 90% out. I then added an outside water filter that you put before the city water connection. I used it all this season. I also found out that there is an in-line system with the charcoal filter near the pump that I didn't know existed. When I drained the water heater to winterize it, I noticed even more white scale than last year. Is there anything that I am doing wrong? What more can I do to stop this or is this normal? I will probably need to change the anode rod at the end of next year. I am probably at 50% now. The water heater has worked flawlessly. I just want to stop the build up if possible. I have to thank this forum for the information. In another thread I found a wand tip that I can stick in there and flush it out better.
KKonyha is offline   Reply With Quote
Old 11-22-2017, 10:24 AM   #2
marinerjoe's Avatar
Is it scale, or is it remnants of the anode that has sluffed off? It could possibly be a combination of both.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 11-22-2017, 11:18 AM   #3
It is a pretty good amount on the bottom. I would guess that I would be able to fill a 12 oz cup with the scale on the bottom.
Old 11-22-2017, 11:28 AM   #4
Iwannacamp's Avatar
Very common when the anode/sacrificial rod decomposes. On my first unit(2 years old) there was at least a cup that came out. I bought a flusher to help get her out.
2017 Puma 297RLSS
Old 11-22-2017, 11:30 AM   #5
If this is normal I am okay with it. I just want to keep it in the best shape I can. Maintenance is cheaper than repair.
Old 11-22-2017, 11:33 AM   #6
It's normal. It's the result of the anode rod reacting with the minerals in the water. The amount of crud and the rate of loss from the anode rod are a function of how much water you put through your water heater and the amount of minerals in the water. More water and/or more minerals = more crud.
It shows your anode rod is working.
2011 Traverse LT, 3.6L, FWD
Old 11-22-2017, 11:38 AM   #7
glsimms's Avatar
Spend about $7 bucks and get one of these:
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 11-22-2017, 11:51 AM   #8
SailorSam20500's Avatar
I don't think the scale is caused by the anode. Scale builds up in both Suburban and Atwood heaters - Atwoods which don't have an anode are also subject to scale buildup. I think scale is caused by hard water. As the water is heated, the minerals in the water precipitate out. A lot of it builds up on the electric heating element if you use it. Just rinsing the tank helps but there is still a lot of scale left that is solidly attached to various surfaces. There are a number of sources that suggest soaking the tank with a vinegar solution to get rid of more of the buildup. Here is one u-tube on the subject:
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 11-22-2017, 12:01 PM   #9
Some of this makes sense. I did buy the flushing wand, which I didn't know existed until someone posted a link. We do use the hot water heater more than the previous owner.
Apparently, the filters do not stop the minerals in the hard water?
Old 11-22-2017, 12:07 PM   #10
No, the minerals are dissolved in the water (similar to mixing water and salt).
The minerals are why folks with home wells add water softeners. The softener swaps the hard water minerals for salt. Same process is what causes stalagmites and stalactites to grow in caves.
Al
S.E. Mich.
Old 11-22-2017, 12:20 PM   #11
Great thanks to everyone. I will just continue to flush the hot water tank out. With the ease of the wand, I will probably do it more than once a year. That way the build up will not get too bad.
Old 11-22-2017, 05:40 PM   #12
Canadian Member
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 11-24-2017, 07:32 AM   #13
360true's Avatar
Check out this very helpful video by RVGeeks: http://www.thervgeeks.com/water-and-...flush-inspect/
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
heater, suburban, water, water heater
