Old 07-02-2012, 10:14 AM   #1
Wanna Be Camper
SaskCampers's Avatar
A repair to the tank area of our V-Lite
In the nose of the V-Lite where the propane tanks are, there is a cover on the back wall made of the same material the belly cover is. I was looking at it and saw it was bulged out and wide open for water etc to hit the wood wall but there is a rubber gasket that would seal it if properly attached so I too a 3/4" wide aluninum strip and drilled it and screwed it down the entire length to pull the panel in and reseal the nose area.
ID:	16002   Click image for larger version
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
