Old 12-23-2019, 11:15 PM   #1
Abco water valve
2016 Dynomax Isata 3. I am replacing the old cartridge style ABCO valve with the new Abco valve that has no cartridge. Has anyone done this. I am concerned anbout the connections on the old valve and if there is enough piping to install the new valve.
My valve is located in the back corner of a side storage compartment and hard to get to. Any comments would be appreciated.
Wes
Tightlines is offline   Reply With Quote
Old 12-26-2019, 11:37 AM   #2
SeaDog's Avatar
I did not know that Anderson Valve company made valves for RVs. I think even tho its tight I would measure the old valve connection to connection and compare to the new prior to removing anything to make sure it will fit.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 12-26-2019, 10:19 PM   #3
Thanks for yourresponse. I did not to tear into it if it does not work. Guess I will go for it. Good spring project.
valve, water
