Old 08-17-2013, 03:42 AM   #1
Access to holding tanks
My father has a Blue Ridge 3125 and we are trying to find manuals on getting access to the holding tanks. Anyone know if there is a repair manual available for this unit or something that is similar? Can anyone provide instructions on getting access to them?
rjfoster03 is offline   Reply With Quote
Old 08-17-2013, 08:21 AM   #2
Great Horned Owl's Avatar
The probability that a repair manual exists approaches zero.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-17-2013, 08:53 AM   #3
Dave_Monica's Avatar
You'll have to remove sections of the underbelly covering. What are you trying to fix?
Dave
Old 08-17-2013, 10:00 AM   #4
Dad has a clogged gray tank. He is going to try back flushing first but just in case... he wants a back up plan.
Old 08-17-2013, 10:19 AM   #5
TURBS's Avatar
How can u have a clogged gray tank as there's no solids in a gray tank
Does his sensors read full or almost full but nothing runs out?
Turbs
Old 08-17-2013, 10:25 AM   #6
Have seen hole saw slugs left inside the tanks,they block the exit. Youroo!!
Old 08-17-2013, 11:27 AM   #7
TURBS's Avatar
Good point!
Old 08-17-2013, 12:25 PM   #8
jonandjolene's Avatar
I have a 2013 Blue Ridge 3125RT and I am sure Dave is correct in that you will have to remove the underbelly covering under the tank. I have not done this, but am sure there is also insulation to be removed. The brackets that support the tank will also have to dealt with if you are going to totally remove the tank as well as the plumbing to it. If the unit is still under warranty, I would return it to the dealer to do.
JonandJolene
w/ TrailAir suspension
2015 Ford F250 4X4, 6.7 PSD
Pullrite Slider Hitch
jonandjolene is offline   Reply With Quote
tank
