Old 08-21-2016, 05:51 AM   #1
Accessing the water pump, Freedom Express 233RBS
Just bought a 2014 Freedom Express 233RBS. Water pump leaking from housing. It is located behind electrical panel and beside hot water tank. You can't get more than your hand through the small access hole. Anyone know how to get to the pump to remove and replace it?
Mmadhatter is offline   Reply With Quote
Old 08-21-2016, 06:12 AM   #2
dbarr's Avatar
When I installed the winterizing valve I pulled the converter, electrical panel, out. There was plenty of slack wiring to set it aside without disconnecting any wires.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2019-33, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....54
dbarr is offline   Reply With Quote
Old 08-21-2016, 04:52 PM   #3
Thanks for the comment. Wasn't sure about the panel removal, but now at least I know someone else did it. My as well add on the winterize valve at the same time. Thanks.
Old 08-21-2016, 05:53 PM   #4
dbarr's Avatar
You're welcome.
Leaving the tube on the valve makes it easier...in fact you might want to get a longer one instead of the one supplied with the kit.
2014-47,
Years camping....54
233, freedom express, pump, water, water pump
