Old 08-19-2010, 07:06 AM   #11
Herk7769's Avatar
Thanks, I will give it a try.
HAM CALLSIGN - KC3FFW
Old 08-19-2010, 07:17 AM   #12
Iggy's Avatar
Originally Posted by dichayer View Post
It will quiet the pump. If you install a bigger unit, the pump will have to keep this large unit full. The acumulators are more to take the shock out of the system than to supply water. Give the small one a try with a pressure setting that is lower than the pump running pressure. This will improve the way your pump sounds. Good luck.
Dick
If you are trying to qiet the pump try installing a cheap mouse pad under the pump. This buffers the sound and vibration.
Iggy is online now   Reply With Quote
Old 08-19-2010, 07:34 AM   #13
Herk7769's Avatar
I have a plumber buddy who gave me several vibration damping squares used to mount AC air handlers and compressor units. I plan on using those in my installation. I was just waiting for a break in the camping schedule to do the work.
Old 08-19-2010, 10:27 AM   #14
miatared's Avatar
Smile
Dick
Dick you are 100% right - I just lowered the pressure to 28PSI and it performs well. It does improve, the pump starts less often - now I can really feel the difference.
I read on the tech data sheet for the classic pump that it is preset to 25 (on) and 40PSI (off) (+- 5)
Thank you so much.
Denis
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 08-19-2010, 12:37 PM   #15
Herk7769's Avatar
I am feeling so much better about this project!
Old 08-20-2010, 07:34 AM   #16
dichayer's Avatar
My pleasure.
Dick
dichayer is offline   Reply With Quote
Old 09-20-2010, 10:59 AM   #17
I let you camper work out the pressure to set for accumulator. One of the good thing about the accumulator is that it help control water expansion , when water heater is doing it thing,reducing high water line pressures. It help stop the T&P valve for leaking.
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
Old 09-20-2010, 02:29 PM   #18
I put a 5 gal. press. tank in our unit.All nite flushing&hand washing,no pump running. Showering with a smooth no pulsing flow of water. The pump cut off press. is 40psi, the air in bladder is 30psi. Works just fine! Youroo!!
youroo is online now   Reply With Quote
Old 09-20-2010, 03:15 PM   #19
DAISY BOYKIN's Avatar
Glad you Fellows figured the pump-tank out
Have thought about it (installing tank), Now that a mix of RV scientist and engineers have figured out everything for me, now I can complete my project
Thanks fellows!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-21-2010, 06:11 AM   #20
miatared's Avatar
Smile
Glad we could help.
That is what these discussion boards are all about: knowledge transfer.
Fantastic.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
