06-09-2018, 08:57 AM
Added Check Valve to outlet of water pump
Hi All,
My Fresh Water tank was filling, when hooked up to city water. I disconnected the city water and ran the rest of the trip off the water, left in the fresh water tank. I figured it should have washed out whatever was in the pump. On the next trip it filled the tank even faster and it was overflowing in the morning, when I went out to check it.
I looked online and everyone said to replace the pump. I wanted to try to add a check valve on the outlet of the pump. I bought a check valve, and a female to female adapter. Installed the valve, making sure the flow was going away from the pump, and then hooked everything back up. It seems to work well on city water, to keep the water from flowing back through the pump. However, when using the pump, it never completely shuts off. The pump will get up to pressure and then turn on and off for about 1/2 second, every 1-2 seconds. Is the check valve keeping the pump from registering the pressure?
Here are the photos of the install:
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
06-09-2018, 09:29 AM
I may have figured out the problem. If the check valve in the pump is so bad, it would let the water back through. This would slightly bring the pressure back down and the pump would start again. Therefore, I am likely going to need to replace the pump.
We rarely use the pump, except for quick pit stops, while traveling. Therefore, I will leave the check valve installed, until I can replace the pump. If we need to use it, we turn it on, use it, then turn it off.
Are there any good pumps, which can be rebuilt instead of replacing it every couple of years?
Ben and Doreen
06-09-2018, 09:37 AM
You can search this problem. Your check valve may be stuck. It a series off and on to clear it. You also do not need to replace the pump. Buy a kit and rebuild it.
06-09-2018, 10:26 AM
Ok. I did the cycle on and off. I also used it exclusively (vice city water) for two days to try to clear it. Those didn't work. That is why I was trying to add another check valve.
I'll look for a rebuild kit.
Ben and Doreen
06-09-2018, 12:35 PM
I installed a manual valve. It is not easy to access, but if I start overflowing the water tank I can close the valve. When on the road the valve is open so we get water for the toilet at rest stops.
This was after replacing one water pump and then the second one failed after a year.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
06-09-2018, 03:18 PM
External check valves are definitely more positive, but "shouldn't" be needed. Assuming the pump internal check is history, and you're not crazy about putting in a rebuild kit, you can also buy replacement heads for most pumps. The motor being the expensive part of the pump, this will save a considerable amount of $$.
06-09-2018, 07:58 PM
Great! Thanks!
Ben and Doreen
06-10-2018, 11:02 AM
Move the check valve to the inlet side of the pump. That should fix the problem.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
06-10-2018, 07:31 PM
X2^
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
06-10-2018, 07:38 PM
Originally Posted by Dwilcox
X2^
X3
2011 Traverse LT, 3.6L, FWD
06-11-2018, 05:30 AM
Wow! Easy! I can't believe I didn't think of that.
Thanks!
Ben and Doreen
06-25-2018, 09:09 AM
I moved the check valve to the inlet side of the pump. It now works perfectly. Thanks again for the suggestion.
Ben and Doreen
08-16-2018, 08:35 AM
Thanks to all. Moved check valve and all works good. Only wish I could help someone else as I am always needing help. Thanks again.
