Adding a drain to fresh water tank
My 2003 Palomino travel trailer has a typical side-mounted drain on the fresh water tank, but over the years the tank has bellied out and the drain is too high to get what appears to be 2-3 or more gallons of water. Is it possible to retrofit a drain to the bottom of the tank, or better, put a hose fitting on the bottom of the tank and run a hose with valve to the side of the trailer so it could be opened without crawling under the trailer. Thanks from the snowy mountains of Colorado.
