Old 01-11-2010, 03:13 PM   #1
adding expansion tank
I am thinking of installing an expansion tank to my water supply. Do I need a check valve to stop the pressure bleeding off, or does the pump have one built in? Any thoughts appreciated.
WillyB is offline   Reply With Quote
Old 01-11-2010, 05:28 PM   #2
NWJeeper's Avatar
The tank only need be installed somewhere after the water pump in the system. It's sort of like an air tank on a compressed air system in a way. See this diagram which may help you visualize it. There is also this page which is very good at explaining RV water systems.
Ed & Wendy
www.nwjeepn.com
Old 01-11-2010, 06:08 PM   #3
NWJEEPER. The water everywhere article covers everything I wondered about, and then some. It is definitely worth saving for future use. Many thanks!
