Old 07-08-2016, 04:07 PM   #11
Originally Posted by grumpy0374 View Post
Thats exactly what I want to do. And as for not having a gfi inline with it, the switch will be turned on when we set up at a spot, and left on as long as we're on shore power. Turned off when we break down. I basically keep it on the electric as I'm already paying for the electric, and no need to waste my gas.
Grumpy
Why would you need a switch? Does it not just shut off from power when shorepower is off anyway?
MtBiker is offline   Reply With Quote
Old 07-08-2016, 04:37 PM   #12
wmtire's Avatar
Getting ready to add an on/off switch for the 115 volt switch on my Surburban WH. Right now I'm controlling the on/off via the circuit breaker, the outside switch being left on all the time.
Rather than get fancy by hooking it up by the fuse panel, I can access the wire via a compartment in the bathroom. Could I not just cut the wire, attach it to the switch, and simply mount the switch in the bathroom?
Basically the outside on/off switch would be left on, and the new inside bathroom switch (with light to indicate on/off) would be mounted to the bathroom cabinet. Circuit breaker switch would be left "on".
Any input welcome.
Grumpy
Grumpy to make sure I am clear on this emboldened in red above. What wire (as in singular) are you talking about? Are you talking about the single hot wire that the outside switch is breaking the circuit on? Or something else?
I was not aware that the outside switch wire was very long as it runs internally from where the water heaters power cord enters the AC junction box on the water heater... to the electric element. I don't know where it is exposed for you to just cut this single wire and add a second switch, without running more wire.
Or are you perhaps talking about cutting into the water heaters power cord (that has a hot wire, neutral, and ground wire in it)?
The reason I ask, since the outside switch is just cutting the 120 volt hot lead (and nothing else, no neutral, no ground), how can you also connect a lighted switch to that one hot line, which usually requires a neutral for the light?
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 07-08-2016, 05:02 PM   #13
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
I did this on our 2014 Silverback 33RL...... Put it in the control panel...convenient because that's where the propane on/off switch is.
Here is the thread I followed.....
Water Heater Switch with Power-on Light
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 07-08-2016, 05:22 PM   #14
Re: switch for water heater in bathroom
If this water heater switch modification is in the bathroom and is within 6 feet of the sink or shower it will not meet the electrical code.
klaatu is offline   Reply With Quote
Old 07-08-2016, 05:34 PM   #15
wbdavey's Avatar
Grumpy - I thought about adding a switch, but decided not to. The switch on my heater is just in front of my water connections on the left front of the trailer. I feel that I'm much more likely to remember to turn the heater off with the switch close to the water hose. Maybe your memory is better than mine.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 07-08-2016, 06:19 PM   #16
Sky&Scuba
kendive's Avatar
I also do this on every camper we owned. I like the switch that has the pilot light so when the water heater is on the light is lit. You can wire the switch either way.
Traded Flagstaff 25KS for a Catalina 253 RKS
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-08-2016, 06:33 PM   #17
northstar1960's Avatar
funny to hear so much talk about codes . you can believe our RV's are up to some code . but they aren't even close . I just replace a water pump in a new unit and it was located behind the distribution panel ,like just a few inches ,wires all over , no code there . if there was a leak it would soak thew converter and panel .
RV codes Thanks for giving me a good laugh it must be the rvia seal that means it's all good . . even in my 29hsf there are things that would not pass usbc codes . like the gfi in the bathroom so stuffed with wires that the cover bows out . CODE hahaha
northstar1960 is offline   Reply With Quote
Old 07-08-2016, 06:47 PM   #18
also worked on a unit last week where they ran the 12volt power for the furnace and fridge over the top of the fridge and the wires melted on the fridge coils . it was a new starcraft . codes still laughing . it would be one thing if inspectors had to sign off on all units just like when a house is built
Old 07-08-2016, 07:01 PM   #19
Mr. Dan's Avatar
Ding! Ding!
I never want/need to turn off my electric water heater circuit unless I'm standing by my hose connections as I pack up to leave a site. If I forget (and I usually don't since I have a checklist), the heater circuit goes dead when I unplug my cord from the pedestal.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-08-2016, 07:08 PM   #20
If you are worried about water, install a GCFI breaker.
2011 Traverse LT, 3.6L, FWD
electric, water, heater
