Old 10-31-2014, 07:52 PM   #11
B and B's Avatar
Gravity drain and Pink stuff. Don't like the gunge out of my compressor.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 10-31-2014, 08:08 PM   #12
Both here as well. Air and the pink stuff. The little things like, residual water at the city water connection check valve.
Try this little test, blow out the city connection, then just to see if all the water is evacuated, pop off the filter screen and press on the check valve. I have found that you still get a small amount of water to bleed out.
Old 10-31-2014, 08:10 PM   #13
I blow my lines out with air, remove the water filter and pour some pink in the p traps. Never had any issues.
fly-swatter is offline   Reply With Quote
Old 10-31-2014, 08:14 PM   #14
ARLO
Both here too.
rlocicero is offline   Reply With Quote
Old 10-31-2014, 08:47 PM   #15
Taranwanderer's Avatar
Both here X6. Just bought a little oil-less pancake compressor from HF for $50, that's going to be my dedicated and portable winterizing compressor. Adjustable output, dial it down to 30 PSI to get as much water out as possible--including blowing out the black tank flush--and then AF through the system with the water pump. Cheap insurance.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-31-2014, 08:55 PM   #16
asquared's Avatar
Here is my recent Winterizing poll
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 11-02-2014, 09:28 AM   #17
RPAspey's Avatar
I go overboard...blow out lines, pump pink stuff, then blow out the pink stuff into a container which I then use in the traps and toilet bowl.
I only use 1 gallon for my 31' TT.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 11-02-2014, 10:01 AM   #18
ironj's Avatar
hook up the 60gallon shop compressor and blow it out till its all air out of every outlet.
gallon of pink for the traps n drains...
slap her on the butt and put her in storage...
I DO NOT like the pink stuff in my fresh system....
if you've ever worked with pex its pretty flexible....it would take a pretty significant amount of water freezing in it to bust one....I would be more worried about the check valves and such that are plastic..
nothing wrong with doing more tho....and if I was gonna use pink only I wouldn't bother to blow out lines....id just pump the pink in till it ran out .....then call it a day
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 11-06-2014, 05:00 AM   #19
thetiler's Avatar
OK I have a question here in NJ
Were heading to Myrtle Beach for Thanksgiving
Its still in the 40s-50s here in NJ
Do you think I should winterize before I leave or just watch the weather till then
I also want to put some Fresh water in the tank before we leave (To use during the trip down) I was planning on doing that right before we leave
On the way back
Do I winterize before we leave Myrtle Beach ? or wait till I get home
Jason
2013 F350 SB,CC Lariat Ruby Red,3.73Gears,5Star Tuned,,Line-X Bed,Extang Platinum Cover,Airlift LoadLifter 5000 Bags,Airlift Wireless Air controller,Reese Signature Series Fifth Wheel Rail Kit,B&W Fifth Wheel Hitch,2014 Flagstaff 8528BHWS
thetiler is offline   Reply With Quote
Old 11-06-2014, 05:50 AM   #20
Witch Doctor's Avatar
I would just do it at home, you should be fine.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
