Old 10-13-2012, 03:58 PM   #1
Love My Sunseeker
DXSMac's Avatar
Air pockets in freshwater tank
Anyone ever have this problem? Seems to happen if the freshwater tank is half full. What happens is...... I try to fill it up, and water spits back at me, won't go into tank. Tank is only half full. Nuisance.
Sometimes it helps if I flush a toilet or run a faucet while the water tank is filling. Or, sometimes just use up the water that's in the tank, and when almost empty, then fill up. But this is a royal pain.
It's happened on all the Sunseekers that I have owned. I believe it's air pockets.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 10-13-2012, 04:39 PM   #2
I have the same problem, but it seems to me that the vent for the tank gets full of water. I have tried to blow the water out with a small hose and and a lot of umph, that seems to help.
We camp on earth with a Sun Seeker 2300
yworrydog is offline   Reply With Quote
Old 10-13-2012, 04:54 PM   #3
Herk7769's Avatar
You need to angle the camper so that the tank is level for the system to work.
As you can see from a photo of my freshwater tank, when I am hooked up to my truck the tank is nose down. The vent line sees water when the tank is half full.
If you angle the camper differently, it will fill properly.
Name:	Horst Probe Install 019.jpg
HAM CALLSIGN - KC3FFW
Old 10-13-2012, 05:04 PM   #4
Gee lou, didn't know we had to level the motor home when just filling the tank....actualy I have had the problem when filling it at home if it was 1/2 full or more. It is level where I park it. Don't think that is the problem, but thanks.
Old 10-13-2012, 05:33 PM   #5
Herk7769's Avatar
The camper's fresh water tank may not be level in the camper. Mine is not; it is tilted forward even when leveled. I would need to raise the nose well above level to get a full water tank.
Old 10-13-2012, 05:34 PM   #6
fast murray's Avatar
I have a vent in the fill area but also a vent hose out the bottom of the RV with a valve that I have to open to keep from getting a bath. Herk, I am truly impressed with not only your collection of photos but also your ability to produce them so quickly.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 10-13-2012, 05:38 PM   #7
Herk7769's Avatar
Also look at the vent line. Yours may even be more sagged.
Name:	Horst Probe Install 020.jpg
Old 10-13-2012, 06:06 PM   #8
Herk7769's Avatar
A vent hose with a valve? Sounds like the drain hose for the water tank.
Mine is that white hose that goes to a toggle drain valve like the other photo.
Name:	Horst Probe Install 021.jpg
Old 10-13-2012, 06:25 PM   #9
Yeah, there are 2 valves on 2 lines down there. One of them is to drain the tank and the other one as I found out through trial and error is a vent. When I open it I could probably fill the tank with a firehose and when water comes out of that line I am full. BTW, the vent valve was added by the previous owner.
2004 Wildcat 28BH
Old 10-13-2012, 06:27 PM   #10
Herk7769's Avatar
Nice. Wish mine was like that.
