Old 06-09-2011, 07:28 PM   #1
an additional switch located above my water tank control panel
Hello all,
I have a 2009 Forest River Sierra. Above my water tank control panel (and water pump and water heater) there is another, separate switch. Does anyone know what this switch is for? Thank you.
Jesse
flywater is offline   Reply With Quote
Old 06-09-2011, 08:13 PM   #2
sherdep's Avatar
how about a picture of said switch
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-09-2011, 08:52 PM   #3
Here it is.....it's the white switch above the monitoring panel
Old 06-09-2011, 09:05 PM   #4
onetonford's Avatar
Might be for lights under counter or toe kick or lights in cabin if you turn it on and nothing happens could have light off at fixture.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-09-2011, 09:17 PM   #5
OneTon,
All of the lights are working. I'm pretty sure it serves some other function.......what that function is though I have no idea.
Old 06-09-2011, 09:21 PM   #6
sherdep's Avatar
maybe an outside light say over a slide - hopefully someone will be able to tell you
Old 06-09-2011, 09:22 PM   #7
Could it be the switch for the receptacle that the awning lights would plug into?
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
nailit is offline   Reply With Quote
Old 06-09-2011, 09:32 PM   #8
onetonford's Avatar
Mine has switches for the rope lights that are under the cabinets and in the bed room head board and I v'e heard that the rope lights burn out rather quickly I know that if my trailer were older and the lights were burn't out you would be hard pressed to find them and the switches are wall mounted. so they are in plain view but the rope lights are well hidden. I know that I already have some of the little bulbs burn't out due to the fact that there is gaps in the light comming from them so they do bun out. If you have the outside scare lights also they tend to put the switches in the wierdest places and some people have a hard time finding them.
2011 25 RL Wildcat
Old 06-09-2011, 09:34 PM   #9
onetonford's Avatar
Could also be for tank heaters also I guess?
2011 25 RL Wildcat
Old 06-09-2011, 09:44 PM   #10
Thanks Folks,
I figured it out.....it's for the automatic overhead vent and fan in my kitchen/dining room/living area. I'm glad I figured that out before going to bed, otherwise I'd be staying awake trying to figure it out. That vent/fan has an individual on/off switch as well as a fan speed control knob mounted inside of it on the ceiling......just had to set these to their correct settings and that mysterious white switch started to open the vent and turn on the fan =)
