Old 11-29-2012, 10:35 AM   #1
Anod Rod Question
Is this how the Anod Rod is supposed to look on a camper that is a few months old?
Mike & Allie
2013 Salem Hemisphere 272BH
2006 Ford F250
PBallie1602 is offline   Reply With Quote
Old 11-29-2012, 10:39 AM   #2
Mine did.
Old 11-29-2012, 10:53 AM   #3
Triguy's Avatar
Yours looks good.
This diagram compares the wear on an anode rod in a general sense. The amount of time it takes really depends on the corrosive elements in your water supply(ies). My current rod looks pretty good even after two good years of camping.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 11-29-2012, 11:12 AM   #4
Thanks! That makes it easy to understand!
Mike & Allie
2006 Ford F250
Old 11-29-2012, 11:30 AM   #5
wmtire's Avatar
X2
You can also extend the life of your rod, by draining your water heater when not in use between camping trips....instead of letting the anode rod stay submerged in water during idle time.
Just looking at the pic, it seems your rod is getting weak near the threaded end. As cheap as the rods are, I would probably go ahead and replace this one since you got it out.
As the rod does it job and deteriorates, it leaves pieces and residue inside your heaters tank, that needs to be flushed/cleaned every so often.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-29-2012, 11:46 AM   #6
TURBS's Avatar
X2 on draining Hw heater between trips .
Got 7 years on my last anode rod and still didn't need replaced before I traded.
Old 11-29-2012, 12:17 PM   #7
MtnGuy's Avatar
I have 4 years on my anode rod, and I don't drain the water between trips.
I don't plan on replacing that puppy anytime soon...maybe when it gets down to the about 25% anode remaining in another 10 years or so.
Old 11-29-2012, 01:20 PM   #8
wmtire's Avatar
I won't get a year on mine down here, if I don't drain the tank. We probably have more chemicals in our H2O.
Old 11-29-2012, 01:36 PM   #9
B47
Attachment 21940
This whole issue of how long each person gets from his/her anode rod has many variables such as the hardness of the water at the various CG's you visit, the chemicals in the various CG water supply, how often you use your RV water heater, etc.
There is no hard life limit that each of us can expect to get from their anode rod.
I guess that is why the anode rod manufacturers don't give a definite life limit.
Old 11-29-2012, 01:44 PM   #10
WMTire how do you flush out the residue inside your heaters tank
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
