Old 09-15-2011, 05:33 AM   #11
rbarrieau's Avatar
the anode can rot out the warter heater female threads, if only a few threads are engaged..
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 09-15-2011, 05:39 AM   #12
Herk7769's Avatar
I flush mine out real well during the winterizing; make sure the bypass valves are in "bypass"; then Teflon tape the threads and reinstall to finished torque.
I experienced corroded threads leaving it partially installed and I worry about bugs getting inside over the winter with it out completely.
HAM CALLSIGN - KC3FFW
Old 09-15-2011, 07:32 AM   #13
MtnGuy's Avatar
If there is no water in the water heater, then the anode rod should not deteriorate during the winter.
Old 09-15-2011, 07:37 AM   #14
jimh's Avatar
i would clean the water heater and put it back in. my logic is more of a thread protector from rust. u aren't going to get a wrong answer on this; it's a matter of preference.
jimh is offline   Reply With Quote
Old 09-15-2011, 07:56 AM   #15
Glenn5995's Avatar
Put it back in would be my recommendation. I left mine out for a short time once and the threads corroded in the water heater portion and I had an awful time trying to get it back in.
Plug or put anode back in?
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 09-15-2011, 08:14 AM   #16
Herk7769's Avatar
I merged these threads. There are 3 current threads running on anode rods. Come on guys, give the moderators a break. At least LOOK to see is the answer to your question is in a current thread before you post.
I realize there may be an old post that is hard to search for, but this question was on the hot sidebar.
I always wanted to use that icon!
anode
