Old 06-29-2015, 02:51 AM   #21
Just a member
kandl's Avatar
Originally Posted by Herk7769 View Post
ALWAYS close the winterization valves to drain your tank to inspect your RV's water heater before you remove the anode rod or repair an electric element. Forgetting can result in tank crud getting into your cold water pipes which can then find their way to the faucets or toilet tank valve as the water "glugs" and stirs up the bottom.
It goes without saying (but I will), never drain your hot water tank through the camper's low point drains. The repair bill you save will be your own.
Good advice, especially for those of us that tackle our own maintenance/ winterizing etc. Cleaning out a plumbing system full of crud from the HWT because... you let it go there, is a PITA. Ask me how I know.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
anode, hot water, tank, water, water tank
