Old 04-04-2019, 07:53 AM   #1
Anode Rod
Anyone ever heard of FR product that did not have anode rode in water heater? A plastice plug for draining HW tank but no A rod?
gbaldwin is offline   Reply With Quote
Old 04-04-2019, 07:56 AM   #2
Yep, you have an Atwood water heater. Perfectly normal.
Iwritecode is offline   Reply With Quote
Old 04-04-2019, 07:57 AM   #3
Mr. Dan's Avatar
Certainly... many. Atwood heaters generally donít; Suburban heaters generally do. Now that was before the names got confused!!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
Old 04-04-2019, 08:35 AM   #4
Flybob's Avatar
Many Atwood owners replace the nylon plug with a valve which makes draining very simple.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-04-2019, 09:27 AM   #5
Thanks All. I was checking mine yesterday which is 2 years old and a neighboring camper came over to observe what I was doing. Had a new (used) TT and was concerned that he knew nothing about an anode rod change. Wwe noticed that plastic plug and he was conceerned that previous owner might have replaced anode with plug for some reason. I didnt know. But the plug was smaller than the anode threads in mine. Wasnt sure. But now we know! Thanks
Old 04-04-2019, 09:31 AM   #6
I've had Atwood water heaters that had the 3/4" NPT plug (same size as Suburban port) and one with a 1/2" NPT plug.
I had to be careful and use a 6 point socket on the nylon plugs as the corners would round off easily using a 12 point socket.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 04-04-2019, 09:50 AM   #7
cavie's Avatar
Atwood heaters are made of Aluminum. No need for an anode rod. Suburban's are steel. Anode rod needed. So I've been told.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-04-2019, 09:58 AM   #8
I was fortunate with our old Jayco with the Atwood. The first trip out I found a brass or copper plug laying on the ground at the campsite. I replaced the plastic plug which already had the edges tore up and kept the plastic one as a spare in my tool box.
TheWolfPaq82 is offline   Reply With Quote
Old 04-04-2019, 04:47 PM   #9
There is a tool for removing the plastic plug from the water heater. It looks like a "T handle" with a tapered, barbed end. They are used on inground sprinkler systems. It works like a easy-out.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 04-05-2019, 10:58 AM   #10
Bob
I regular socket works just fine.
anode
