Old 09-23-2012, 08:55 PM   #1
Anode rod
Tired of getting all wet when i take the anode rod out.Is there a
rod with a drain valve on it &were can i buy one.
2012 Cherokee Grey Wolf
2003 Toyota Tundra
Grey Wolf is offline   Reply With Quote
Old 09-23-2012, 08:58 PM   #2
Mark and Linda's Avatar
Relieve the pressure first on the hot water heater, then sort of stand back, when you remove the rod. I still get wet...always wear my crocs and have a towel close by. Bought my socket at Lowe's...around 6 bucks, has a lifetime warranty.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 09-23-2012, 09:22 PM   #3
bob213's Avatar
They make one for the Attwood but not the Suburban.
http://www.rvplus.com/camco-mfg-4-1-...FeeDQgodKkkAwA
bob213 is offline   Reply With Quote
Old 09-23-2012, 09:47 PM   #4
Road-King's Avatar
Originally Posted by bob213 View Post
That's kind of weird, I didn't think the Atwood even used a anode rod...
It seems like I have seen one for the Suburban, but your giving up some of your anode. You would need to replace it more often.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-23-2012, 10:31 PM   #5
Agree that you always need to relieve the pressure with the pressure relief valve at the top of the HWH before unscrewing the anode rod. Then the water will flow, not spray, out, especially if it is still hot.
If you want to stay dry (and unscalded), keep the plastic edge cleaning tool from your vacuum cleaner nearby when you loosen the hex nut. Fit the large end over the hex nut when the water starts to flow. This creates a spout that prevents water and sediment from running all over the bottom of the HWH enclosure (and down your pant leg).
"Retirement is the best job I ever had!"
2016 Rockwood Signature Ultra Lite 8244WS 5th Wheel; 2015 Ram 2500 4x4 CC-SB 6.7L CTD
Sold: 2012 Rockwood Mini Lite 2109S
fanrgs is offline   Reply With Quote
Old 09-24-2012, 05:54 AM   #6
Herk7769's Avatar
Some ways to do this without getting your "tennies" wet.
1) The water heater can be drained through the low point drains by opening the hot water low point drain (red one) and walking away. It will glug for about 30 minutes. (This is NOT recommended, however, because debris from the tank will enter your hot water lines and may clog a valve when you put water back into the camper in the spring.
2) Make (somehow) a Suburban RV anode rod with a valve in it. "I" do not recommend this because it will be expensive, it leave all that crud in the tank, and it will NOT be permanent (they still need to make a new one every few years as the anode is consumed).
Camco 11533 RV Anode Rod with Drain for Aluminum Water Heater : Amazon.com : Automotive is only for an Atwood water heater with aluminum tank (that of course does not need one). Totally useless, IMO.
The threads are different and will not fit a Suburban (that actually needs an anode rod).
HAM CALLSIGN - KC3FFW
anode
