Old 07-29-2014, 09:30 PM   #1
Thekipkers's Avatar
Anode rod life/water filter
Good evening.
After our last trip (4th do far) I removed the anode rod to flush the HW tank out. I noticed the anode rod is almost worn through close to the threaded plug and will need to be replaced soon.
We have primarily camped at state parks so far, if I use an inline water filter will this help in the life of the rod at all? Or is this just the normal life expectancy of them.
Thekipkers is offline   Reply With Quote
Old 07-29-2014, 09:36 PM   #2
There is (LOTS) of life left in your (A-Rod). Youroo!!
Old 07-29-2014, 09:43 PM   #3
Denver, CO
garbonz's Avatar
Water filter has not impact on the anode rod. It is more a question of the PH of the water and the total dissolved mineral content of the water. Just replace it they are cheap.
2017 Fuse 23T
Old 07-29-2014, 09:49 PM   #4
wmtire's Avatar
Originally Posted by Thekipkers View Post
Good evening.
That's how the anode rods normally wear, starting at the end nearest the threads.
There is a chart taken from Suburbans service manual at the following link that will show you when you need to replace the rod, which is normally around 75% of the rod dissolving.
Anode facts and FAQs
As Youroo stated, you are still good to go for awhile.
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 07-31-2014, 10:37 AM   #5
Spikedog's Avatar
The condition of the water tank is also a major factor. Old tanks use up anode material faster than new tanks, especially if some corrosion has already taken place. It's a function of anode/cathode active surface area. Same thing happens in your house's water heater.
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
Old 07-31-2014, 11:41 AM   #6
vinmaker's Avatar
As was said. They are cheap and all one needs to do is monitor it each time you drain you drain your tank pre winter.
Old 09-15-2014, 12:40 PM   #7
ARLO
Has anyone ever seen one this bad? Only two years.
rlocicero is offline   Reply With Quote
Old 09-15-2014, 12:57 PM   #8
Looks like that one was broken or not all there when it was installed. I would definitely be cleaning out the tank to see where the rest of it is. I would guess it's all in the bottom of the tank.
Old 09-18-2014, 08:13 PM   #9
ARLO
It was all there when I installed it. OOPS!
Old 09-18-2014, 08:40 PM   #10
j2detroit's Avatar
I pull mine at the end of each season clean it up and use it next year I change it every 3 seasons
j2detroit is offline   Reply With Quote
anode, water, water filter
