Old 12-30-2015, 01:12 PM   #21
TeflonTape
The threads will cut through the tape to give good contact.
RussPastuch is offline   Reply With Quote
Old 12-30-2015, 01:33 PM   #22
ARLO
I always use teflon an for the winter I have a plastig plug that I screw into the hole.
rlocicero is offline   Reply With Quote
Old 12-30-2015, 01:49 PM   #23
Have used teflon tape for over 20 years with no problem.
VMI'62
Edmund is offline   Reply With Quote
Old 12-30-2015, 01:56 PM   #24
Telstar's Avatar
Suburban suggest using it. If you don't the threads may rust and you will have a heck of a time getting it loose.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 12-30-2015, 02:10 PM   #25
Tom48's Avatar
Originally Posted by MtnGuy View Post
I use teflon tape. The threads should cut through the tape and give you good metal to metal contact unless you use a whole roll of the tape. 1 or 2 layers should be a plenty.
X2
Tom48 is offline   Reply With Quote
Old 12-30-2015, 02:27 PM   #26
The Teflon tape is designed to seal and lubricate the threads. By using it you should not have any leaks and it will be easy to remove the Anode Rod. Just wrap the threads three times and screw it in.
Phil M is offline   Reply With Quote
Old 12-30-2015, 03:22 PM   #27
jkoenig24
Yes, use a few wraps of Teflon tape.
jkoenig24 is offline   Reply With Quote
Old 12-30-2015, 03:30 PM   #28
Mr. Dan's Avatar
OP, did you get your question answered?
Old 12-30-2015, 05:11 PM   #29
labarn's Avatar
I have read all replies and now want to add my experience.
We winter in Az and have for 14 winters. I changed the anode rod and flush the Water tank. One time I did this and the rod was like brand new but a little rust showed in the water as it was draining. Later I read on an rv forum too many wraps of T tape doesn't ground and the tank will rust out. I remember doing more wraps on the earlier replacement of this rod. I replaced the WH at home just because and have changed to a wrap and maybe a half. Now a friend removed the anode rod because a neighbor decided he needed a drain cock install so that was not good. Nothing but rust came out of his tank when I removed the drain valve for him with a lot of effort.
labarn
labarn is offline   Reply With Quote
Old 12-31-2015, 08:46 AM   #30
Wolverine 1945's Avatar
wmtire has said it all !!!
Wolverine 1945 is offline   Reply With Quote
Old 01-02-2016, 12:39 PM   #31
Teflon tape
Glen & Lee
Cleveland, GA : Rochester, NY
2019 Primetime Sanibel 3851
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 01-03-2016, 08:18 AM   #32
Where did you get the plastic plug,,, are they regular plumbing threads ???
Old 01-03-2016, 08:42 AM   #33
Any plumbing supply has (1/2" or 3/4") plastic pipe thread plugs! Youroo!!
Old 01-03-2016, 09:01 AM   #34
Thanks,,, I tried hose fittings,,, just a hair to big !!!
Old 01-03-2016, 10:25 AM   #35
I always use teflon tape. The pipe threads are tapered not straight and when using teflon tape always leave one thread at the end of the pipe/plug free of tape so you don't get pieces left in the tank. Again it is a lubricant as well as a sealant.
anode
