Old 04-08-2014, 06:35 AM   #1
PhotoMaster's Avatar
Anode Rod Water Leak
Just took our RV out for it's first trip. I re-installed the anode rod flushed and sanitized the system. At the camp site I noticed a wet spot on the ground beneath the water heater. Upon inspection I noticed it was leaking around the anode. This is a new 2014 FR3. The rod has a good amount of Teflon tape on it and I don't want to tighten it up any more than I have already, for fear of stripping it out. I'm afraid to bring it to the dealer because I don't want to be without it for weeks on end now that camping season it's here. I've removed it, and applied new Teflon tape, but am still having the same leak. Any advice/help would be appreciated.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 04-08-2014, 06:38 AM   #2
Herk7769's Avatar
Greg, Can you take a photo?
You might be able to snug it up a few threads if there is enough showing.
Herk
HAM CALLSIGN - KC3FFW
Old 04-08-2014, 06:46 AM   #3
mark0224's Avatar
Try plumbers dope instead of Teflon tape but before you re install anode clean any rust in the thread out with a wire wheel on a drill . Don't get real aggressive with the wire wheel and ruin the threads just get rid of any rust. More than likely there is some rust creating the problem and that will ruin tape and leave a spot to form a leak.
mark0224 is offline   Reply With Quote
Old 04-08-2014, 06:49 AM   #4
2014 FR3 30DS
Old 04-08-2014, 06:49 AM   #5
Dave Lyon's Avatar
I would consider removing the anode, inspect, reapply teflon tape and reinstall the anode. If it continues to leak, buy a new anode and try it.
If that leaks - back to the dealer for warranty.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 04-08-2014, 06:57 AM   #6
The anode rod is pretty much new. The RV was built in October 2013 and by December it was winterized by the dealer and the rod was removed. It was only back in the heater for about 3 hours, when U saw the leak. I removed it, retaped it and put it back. It's still leading. The threads look clean.
2014 FR3 30DS
Old 04-08-2014, 06:57 AM   #7
Herk7769's Avatar
Yep, out it comes. That should not leak that far in. However, you can certainly try snugging it up a quarter turn to make it stop first. (edit add)
(This is not your case since you posted below the rod is near new - edit add - but included for those who might have an old anode)
Inspect the threads of both the tank and anode. If the anode threads are really bad, you may also have a rust through pinhole in the anode fitting itself where the wired is welded to the cap.
Worst case, replacement of the anode should fix your problem; I doubt the tank itself is the culprit.
OK, I read your (at the same time) post.
Are you SURE the the anode is the source of the water and not the pressure relief valve above it? Opening and closing the relief valve may clear any debris that might be causing it not to seat.
Name:	Hot Water Heater.jpg
Old 04-08-2014, 07:08 AM   #8
Remove the A-Rod and acquire a (3/4 NPT pipe Tap) and retap the threads for cleanup. Use a Shop vac for cleanup. Retape the Rod and reinstall. Youroo!!
Old 04-08-2014, 07:11 AM   #9
Pressure relief valve is good (checked that first). I'll see if Home Depot has the necessary tap.
2014 FR3 30DS
Old 04-08-2014, 07:13 AM   #10
Herk7769's Avatar
3/4"-14 NPT Carbon Steel Pipe Tap| DrillsandCutters.com
For thread chasing this is an inexpensive option...
