03-23-2014, 05:50 PM
anode tap rusted out... replace with?
I just bought a used 2007 Cherokee camper knowing that the water heater needed repaired or replaced, it's an sw6de. The anode rod tap is completely rusted out (previous owner said it was leaking) My questions 1. Is there any way to repair this? 2. If not, would it be wise to replace with the much cheaper (electric only) 6 gallon water heater found at lowes? And lastly, if I replace it with the oem water heater, is this a tough job? I'm somewhat mechanically incline and it looks easy enough... thanks for any help!
03-23-2014, 05:57 PM
Are you saying the fitting the anode screws into is gone or that the anode is rusted thru and needs removing? How about a picture?
03-23-2014, 06:07 PM
Sorry.. it's the fitting that the anode screws into. Still trying to figure out how to post pics from my cell phone.
03-23-2014, 06:14 PM
pic
Pic
03-23-2014, 06:17 PM
I think you could drill it out and re-tap with a 3/4"NPT tap. I'd try to get the anode out first with a 1-1/16' 6pt socket, 6" extension and a breaker bar.
03-23-2014, 06:19 PM
thats scary ... new water heater time .. if you need it ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
03-23-2014, 06:22 PM
I would soak that thing with Navy Jell or something for like a month and then I would heat it up before trying to move it with a LOOONNNGG bar.
03-23-2014, 06:23 PM
I'll take the anode out to see what I'm dealing with. Thanks. I'm thinking new water heater also. Just wanted to get opinions before I shell out $350
03-23-2014, 06:26 PM
Do you know if there is an RV salvage outfit in your area?
Might get a good deal and save a few bucks while you are at it.
03-23-2014, 06:34 PM
Don't think I'd use a torch around there for fear of setting something on fire behind the sheet metal housing.
03-23-2014, 06:46 PM
I can see that, but if the heat is applied to warm not red hot?
03-23-2014, 06:50 PM
I'd just soak it with WD40 for a week, try the 6pt socket, extension and breaker bar and if that didn't work, drill it out and re-tap. In fact, I'd just drill it out and re-tap it to begin with if the socket, extension and breaker didn't work even before the WD 40.
03-23-2014, 07:09 PM
From your picture - ifs that's any indication of what the rest of the WH condition might be (inside and out and where you can't see) I would seriously consider just replacing the entire WH and be done with it.
03-23-2014, 07:14 PM
I'd have to try removing and re-tapping just for the challenge.
03-23-2014, 07:15 PM
The rest of the wh doesn't look toooooo bad but you're probably right. I don't want to chase problems on this thing. What about replacing it with a home wh? Have any of yall tried this?
03-23-2014, 07:28 PM
That's certainly an option - I would just suggest trying to removing and re-tapping it AFTER the old WH is removed and the new WH is installed. That way after you have cussed up a blue streak for even trying,you can simply look at the newly installed new WH as you walk by it on the way to the garbage can to throw the old WH in.
03-23-2014, 07:33 PM
That would have to be a (Short)W/H! I would try the (Soak & Remove & Retap)first. Then I would turn off the rear bypass valves and Put (40PSI) Air pressure in the tank thru a (3/4NPT bushing to a 1/4 Air quick dis.) that way if you have a Leak you can hear it and NO Water mess to clean up! Youroo!!
03-23-2014, 07:47 PM
My Park model doesn't even have a anode rod, the Atwood came with a plastic plug. That would be an option if the threads are all mess up. It doesn't owe you anything and if it rots no big deal.
Brian
B and B
03-24-2014, 09:58 AM
I got the anode out, this is what it looks like. Apparently it was never changed. Surprisingly enough, the threads aren't that bad. The problem is this thing was completely full of calcium (hard water) and when I went to flush it I noticed from the inside of the camper there's a small leak coming from under the wh somewhere. Looks like I'm going to have to pull it out anyway to see if I can find it.
03-24-2014, 10:00 AM
If I pull the wh and put pressure on it to find the leak, how much air pressure should I apply?
