11-12-2013, 11:08 PM
Anode time??
Dang...this is from a 3 year old trailer. I guess it never got drained. I wonder if I can get another season out of this one?
2017 Puma 297RLSS
11-12-2013, 11:31 PM
That's about as thin as i've seen one!
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
11-13-2013, 12:15 AM
Now you have me thinking... I've asked the dealer to check mine every year but I have never been charged for one. So I guess I'll break out some tools and see if I can find a breaker bar tomorrow.
11-13-2013, 04:21 AM
I would replace it every year. They are pretty cheap and will save your hot water tank.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
11-13-2013, 04:33 AM
Originally Posted by Iwannacamp
Yes you can, as long as your season consists of never filling up your heater with water.
I agree with tomjsas, that's one of the most depleted rods I've seen.
Did you go ahead and flush out the heater, to boot?
2011 Flagstaff 831 RLBSS
11-13-2013, 07:00 AM
That anode rod is done. There's no sacrificial material left. It did it's job fosho.
11-13-2013, 07:20 AM
Of course you can replace it every year but if it's not eaten away
at the end of the season, (as most won't be in just one year) you're wasting
your money.
My 2¢
Peace!
Dan & Rita D
11-13-2013, 07:50 AM
Wmtire.. The tank was full and belched out "kitty litter" as it was draining. There is a lot of that anode material on the trailer, tire, ground etc I thought I would bring over the hose and back flush before I reinstall. It was pretty bad.
2017 Puma 297RLSS
11-13-2013, 07:56 AM
Always Learning
Is definitely flush out as much as you can. For a few bucks, you can buy a wand flushing tool (Camco makes a knock off). Or, I think OldCoot fashioned up some kind of crazy vacuum for his.
11-13-2013, 08:22 AM
Attachment 42552
He said "tongue in cheek"...
That one is shot as you know.
Here is the replacement guide for anyone else.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
11-13-2013, 08:25 AM
What you are seeing is the steel center wire that supports the anode material and NOT the anode material (which is GONE).
Here are pictures of new ones to compare.
11-13-2013, 08:46 AM
You can cut a washing machine hose in half and get 2 "flush out" hoses.
Since the water heater tank is round on the bottom (not flat like
a home water heater) most of the debris is in one pile. I get pretty
good flush out with just a cut piece of hose. OR buy a flusher probe
like others have suggested. You don't have to get every speck out.
I guarantee your home water heater has WAY more junk in it than your
RV will after just a hose flush out...
Peace!
Dan & Rita D
11-13-2013, 08:57 AM
The 'kitty litter' is calcium deposits and not completely from the rod. 'Flushing' will only get a certain amount out of the tank as there is a lip on it. A shop vac with a modified attachment will suck out a lot more and not have a mess running down the side of the TT.
Brother Les
11-13-2013, 06:56 PM
Thanks to this forum for reminding me I had never been charged for a new rod! As you can see I needed a new one last year... Flush out went well but dang there was a lot of 'stuff' in tank!
11-15-2013, 09:03 PM
How do you get one out when they appear to be rusted in without damaging waterheater?
11-15-2013, 09:12 PM
Soak the threads with Liquid Wrench then try and remove it using a lot of muscle. To prevent this from happening in the future, make sure you remove and inspect annually and reinsert after you've wrapped with teflon tape.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
11-15-2013, 09:19 PM
A hammer, wd-40 and time.
Tap the rod with a hammer, spray with WD wait for 15-20 min and repeat.
After the second go around try to remove the rod.
11-15-2013, 09:28 PM
Apply a penetrating oil as Lloyd suggested.
WAIT for about an hour and tap the anode lightly with a hammer.
The goal is to work the OIL into the rust bound threads, NOT break it loose.
If you hit it too hard you can break the porcelain liner inside the tank.
RE apply the penetrating oil, wait another hour and tap (repeat several times).
Using a CORRECTLY sized ( 1 1/16 inch) socket and a long breaker bar or impact wrench try to remove the anode. It should come out.
If not, you could try drilling it out but you will need to use great care that the drill does not come in contact with the threads. Failing this replacement may be your only option.
Obviously, prevention of this situation is preferred.
11-18-2013, 12:49 PM
I sprayed it with penetrating oil twice and let it work it's magic for about an hour. I used a socket/ratchet and it came off without a problem. I did not want to use a hammer or breaker bar to start as I thought it would cause damage. I got lucky in this case but I suspect a new water heater is in my future.
11-18-2013, 12:53 PM
I doubt it if you are basing that on just the anode being gone.
