Old 11-12-2008, 07:29 PM   #21
welshman599's Avatar
Send a message via MSN to welshman599
Originally Posted by KyDan View Post
My mistake.
RV antifreeze is rated 50 BELOW.
That's cold!!!!
Frig, up here -50 is a pretty brisk day eh.
The idea of the antifreeze expanding and bursting the filter canister is worrisome. Here is what Camco says about it on their website:
Q. What is the difference between freeze point and burst point of antifreezes?
A. The freeze point is the temperature of the solution where ice crystals will start to form in the solution and it will have difficulty flowing. This temperature is around +10 F with -50 RV Antifreeze. This temperature is not indicative of the winterizing protection. RVers need to be concerned about the burst protection. The burst point is the temperature where the solution will begin to expand and thus cause the pipes to burst. A unit winterized properly with -50 RV Antifreeze should show a freeze point of around +10 F, which indicates a burst protection of -50 F.
Q. How can I test the antifreeze in my plumbing system to make sure I have the proper burst protection?
A. The best assurance is to follow the instructions on the label and be careful to remove all the water from the system before winterizing to avoid dilution of the antifreeze. Camco offers an instrument called a refractometer which accurately reads both freeze point and burst point of the propylene glycol solution. This instrument is used in all of the Camco facilities to check the quality of our blends at the time of manufacture.
Q. I had some -50 RV Antifreeze stored in my garage and I noticed it was frozen. Is your product defective?
A. No. Propylene glycol antifreezes are designed to provide burst protection to temperatures of -50 F or below. Ice crystals will start to form in -50 RV Antifreeze at temperatures around +10 F and will appear to be solid ice at around -10 F to -15 F. Propylene glycol based antifreezes continue to contract and will not expand until temperatures of -50 F are reached, thus providing burst protection for pipes. If you need a product that flows at the lower temperatures, a higher concentrated product such as Winter Ban -100 or our Ban Frost Marine Engine Antifreeze should be used.
So, from that, unless you hit -50 there should be no expansion IF you got all the H2O out when you winterized. If not, according to Camco, the properties are dramatically altered, meaning you're screwed.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 11-12-2008, 07:33 PM   #22
Originally Posted by Jo-Mae View Post
We bought one of those funnels with the hose attached to it. The tip of the hose is a perfect match to fit inside the bypass line. We have winterized the Surveyor two times so far this fall. Leaving the Surveyor unwinterized between weekend outings would be asking for trouble. Putting the funnel hose in the bypass line works like a charm, so long as I keep pouring in the anti-freeze while the pump is running.
Jo-Mae
Handy hint. a hand-shower hose from your house fits the inlet side of your pump just fine and is really nice and flexible and long enough to allow placement of antifreeze bottles where you can most easily work with them.
